Iulika, uite ce zice Castrol pentru masina ta:
[list]Make BMW
Model 3 Series: 325i/is Coupe, -Convertible (M50, E36)
Engine P
Year 1990-97
Application Recommendation Capacity (ltr)
Engine (P) Castrol's best oil for your vehicle EDGE SPORT 0W-40 (a) 6.5
Alternative recommendation GTX MAGNATEC 10W-40 (a)
Manual Transmission (e,h) 1.2
Automatic Transmission (f) 3
Differential REFER TO MAIN DEALER 1.7
Coolant ANTIFREEZE 10.5
Brake Fluid RESPONSE SUPER DOT 4
Wheel Bearings LM GREASE
Differentials - Front/rear (with non-limited slip differentials or with viscous differential lock) REFER TO MAIN DEALER
Limited Slip Differentials - multi-plate/lamella/electro-hydraulic SAF-XJ (Special Order Only)
Hide Notes Oil Change Intervals
Lubricant / Capacity Notes
a. Engine oil recommendations: EDGE 0W-30 for all engines except S62/E39 up to Feb 2000; EDGE 0W-30 may also be used in all engines except N42, N62, W10-supercharged (and S62 /E39 up to Feb 2000); Longlife-01FE (Fuel Economy) may only be used in N42, N62 and W10 engines
e. Manual gearboxes: units with orange label with wording 'ATF Oil', TQD; units with green label with wording 'Special Oil', REFER TO MAIN DEALER. The labels are located next to the oil filler plug
h. Manual gearbox units with yellow label with wording 'MTF-LT-1': REFER TO MAIN DEALER; units with yellow label with wording 'MTF-LT-2': REFER TO MAIN DEALER;units with no label: SYNTRAX UNIVERSAL. The labels are located next to the oil filler plug
f. Automatic transmissions: ZF 3HP22, ZF 4HP22, ZF 4HP22EH, 4HP24, A4S270R/310R/310Z (with black rating plate), TQ DEXRON III; A5S310Z, ZF 5HP 19, ZF 5HP 24, ZF HP30 (with green rating plate), REFER TO MAIN DEALER; all others, check label for special lifetime fill requirements. Always check manuals/labels to ensure use of correct fluid
General Notes
1. Power steering (where fitted, without combined self-levelling suspension and brake booster servo system): TQD
2. Power steering with self-levelling suspension and brake booster servo (where fitted- reservoir in engine compartment): E24, E28; REFER TO MAIN DEALER/LHM prior to 9/87. After 9/87 use REFER TO MAIN DEALER only; E32 prior to 9/91 use REFER TO MAIN DEALER only; E32 and E34 from 9/91 use REFER TO MAIN DEALER only. Always check label on fluid reservoir for correct type of fluid.
3. Self-levelling suspension (where fitted, reservoir in boot): REFER TO MAIN DEALER/LHM; before Aug 1987: REFER TO MAIN DEALER. REFER TO MAIN DEALER and REFER TO MAIN DEALER may be mixed but neither should be mixed with LHM
4. Clutch fluid: RESPONSE SUPER DOT 4; (except E36/E46 M3 models with sequential M-Transmission and E46 with sequential transmission S5D 320Z: REFER TO MAIN DEALER)
5. Capacities for auto. transmissions are drain/refill capacities
6. Petrol engine oil viscosity recommendations: -20°C to 10°C, 10W-30; -20°C to 20°C, 10W-40; above -15°C, 15W-40; below 10°C, 5W-30; below 0°C, 5W-20. Oils listed and approved under BMW 'Longlife Oils' for all year round use: 0W-X and 5W-X
7. Diesel engine oil viscosity recommendations: -30°C to 30°C, 0W-30/5W-30, above -30°C, 5W-40/5W-50; -20°C to 30°C, 10W-30; above -20°C, 10W-40/10W-60. Oils listed and approved under BMW 'Longlife Oils' for all year round use: 0W-X and 5W-X
8. Use only BMW approved automatic transmission fluids and final drive gear oils
9. All models with service indicator: oil change interval varies with driving conditions, typically 15000 miles/24000 km
10. Cooling systems. Use ANTIFREEZE at a concentration of 50% or one part ANTIFREEZE with one part water
For more information on any of our products, including where to buy, please contact the Technical Helpdesk.
Phone: 01793 452222 Email: autotechenquiries@castrol.com For Heavy Duty and Distributor enquiries, please call 01908 853133.
Disclaimer
© copyright OATS T's and C's
[list]
Nu vad 10W60 scris nicaieri
(exista modelul la ei pe site, don't worry)
