15 Pages V  « < 2 3 4 5 6 > »
> E46 318d, miniduba
post Mar 3 2016, 05:46 PM
Post #61
Uuu, deci am intuit bine, ca e facut sa nu incarce la pornire.
Uite ce zice de alternatoarele "cu doi pini in fund"
QUOTE
Start load response function:
This function is intended to shorten the engine starting procedure particularly at low ambient temperatures. The task of the function is to eliminate a braking torque acting on the engine as the result of full excitation and current output. As a result, during the first few seconds the load current is limited to 0 A in order to achieve the full power output in the following few seconds increasing at a rate of 10 A per second.
post Mar 4 2016, 10:03 AM
Post #62
Da. Cica pentru o pornire mai usoara, sa nu stresezi motorul abia pornit.
post Mar 4 2016, 05:03 PM
Post #63
Da, spunea si Nick ceva de alta inventie cu acelasi scop: ambreiaj pe fulia alternatorului.
post Mar 4 2016, 11:22 PM
Post #64
Crazy.
Fac alternatoare capabili de sute de amperi si apoi trebuie limitat curentul. Cea de la E12 de 55A ce are.
andy_e34
post Mar 5 2016, 07:19 PM
Post #65
27% BMW corupt
Car: E34i,E34iA,E34i,E39iA
Engine: M52B20 150CP
S-o stapanesti sanatos si fara probleme TIL!. Ca sfat, verifica clapetele de plastic din admisie si schimba-le cu unele de metal fixe!. Neaparat sa faci asta, ca ''altii'' au patit-o si e nasol!! se desprind, se pulverizeaza si ti le trage pe admisie in motor!!!
De altfel, spor!!!
This post has been edited by andy_e34: Mar 5 2016, 07:20 PM
they don't make them like they use to !
post Mar 8 2016, 01:58 PM
Post #66
Multumesc!
N-am studiat chestiunea, am inteles de la colegi ca 318-le nu ar avea clapetele alea.
Bart, E12-le nu are toate balariile electrice, resou sub fund, motorase pe la fiecare clapeta, geamuri electrice....
post Mar 8 2016, 03:48 PM
Post #67
14V x 55A = 770W.
Geamuri si clapete nu consuma tot timpul, pentru asta e baterie, buffer de energie electrica. Resoul da, dar cat sa fie. Eu cel putin nu stau bine pe sute de W.
post Mar 8 2016, 05:48 PM
Post #68
post Mar 8 2016, 09:27 PM
Post #69
W, nu kW, adica.
post Mar 9 2016, 10:52 AM
Post #70
QUOTE (bartro @ Mar 8 2016, 03:48 PM) *
14V x 55A = 770W.
Adica aprox 1.05 cp.
Adica electromotorul trebuie sa bata o parte din puterea asta, plus puterea necesara sa invarta motorul.
In conditiile in care electromotorul de tractor (4.7litri diesel) are doar 4cp, unul de masina ar trebui sa fie pe la 1cp. Aproape ca-l pune-n fund doar alternatorul.
post Mar 9 2016, 11:02 AM
Post #71
La turatie mica de pornire mai mult ca sigur nu face mare treaba, alternatorul, nu consuma atat.
La 2002 parca avea 0,8cp, la M30 parca 1cp, electromotorul.
post Mar 9 2016, 12:09 PM
Post #72
QUOTE (bartro @ Mar 9 2016, 11:02 AM) *
Asa-i, dar si daca mananca 20% din putere doar alternatorul, tot e mult.
post Mar 16 2016, 11:56 AM
Post #73
Aproape 4000km, consumul pe ultimul plin a sarit la de la 5.85 la 6.2, ca am condus-o mai normal, fara multe menajamente. Per total 5.97.
Pe bord media s-a dus de la 5.7 la 5.8.
Dupa primele doua plinuri emissile calculate de sprit monitor erau 154g/km, foarte aproape de cele 155 din carte.
Acum se duce spre 160.
https://www.spritmonitor.de/en/detail/744311.html
Articulatia fata bate zdravan, posibil si ceva pe spate.
post May 6 2016, 10:02 PM
Post #74
Aseara am facut pana prostului fix cand intram in benzinarie. Nu mai alimentasem de 1125 km biggrin.gif Bordul arata ca mai duce 31km
Ma gandesc la articulatia fata, ca hodorogeste in ultimul hal. Sa iau bascule complete sau pivoti la bucata pe care sa-i presez in bascule.
Cu pivotii ies aproape de 10 ori mai ieftin. Dar restul banilor ar trebui dati probabil pe asa ceva:
https://www.youtube.com/watch?v=sPYDuuj_2Kg
http://sculeexpert.allshops.ro/produs/1308...92810.2054.html
Mai trebuie sa gasesc si o furca de scos pivotii.
Pareri, idei?
post May 7 2016, 10:26 AM
Post #75
cica merge treaba cu pivotii ,doar ca se scot cu presa cu cu furca.erau cativa care faceau asta.
post May 7 2016, 11:54 PM
Post #76
Verifica flansele de la amortizoare daca hodorogeste tare. Am patit la fel la rsp, se auzea tare pe dreapta si-am aflat apoi ca e "boala" lor. Nah, nu stiu cum suna la tine, dar la mine era o chestie gen metal pe metal, dar pronuntat si infundat, habar nu am cum sa explic laugh.gif
post May 8 2016, 10:45 PM
Post #77
QUOTE (xox @ May 8 2016, 12:54 AM) *
Suna a ceva muzica metal
post May 9 2016, 09:41 AM
Post #78
E cantec de pivoti la mine.
Alex, tocmai despre presa de extras pivoti din bascule sunt cele doua link-uri puse de mine. Dar e 11 milioane presa.... Mai pun furca de extras pivoti, desi pentru asta cred ca pot sa improvizez ceva cu fiarele pe care le am in curte si cu flexul.
Daca stiti unde pot gasi prese/extractoare de-astea mai ieftine, astept cu nerabdare biggrin.gif E doar 110$ pe Amazon....
post May 12 2016, 12:51 PM
Post #79
Am ramas cu masina incuiata, cheia nu o mai deschide prin telecomanda. Butucul din usa nu merge , nu incuie nu descuie.
Aparent touring-ul nu are inchidere cu cheie la portbagaj, deci nu pot sa incerc acolo. Nici la usa pasager nu are.
Presupun ca bateria cheii e dusa. Sunt multi care zic ca daca schimb bateria trebuie sa resincronizez cheia cu masina, proces ce ar presupune masina descuiata.
Asa ca mi-e teama sa merg sa schimb bateria. Ma gandesc intai sa improvizez o alimentare in paralel cu 3 V a cheii sa descui usa si apoi vad eu.
Pe net vad destule filmulete mai mult sau mai putin credibile care zic ca au schimbat bateria si e ok.
Altii comenteaza ca trebuie pus acumulator, nu baterie.
https://www.youtube.com/watch?v=wOP3DZBuhz4
https://www.youtube.com/watch?v=UqgJrgXCVQU
Am sunat la diagnozasector5.ro au zis ca nu pot sa ma ajute pana nu descui masina. Cheia m-ar costa 100E si mi-ar gasi un infractor sa deschida usa pentru 250 lei. Enorm.
drujbex
post May 12 2016, 04:41 PM
Post #80
Engine: M50 2.5 192CP
nu cumva e dusa bateria masinii?
cica poti deschide capota daca scoti atent narile.
am mai auzit 'povesti' cu scosu' semnalizatoarelor (alea de pe aripi) si dat curent pe-acolo ...
tocma ce-am vorbit cu un coleg cu experienta first hand la propriul e46:
el a ales varianta in care "cracanezi usa" desfacand chederul in partea de sus si bagat un lemn ceva si apoi folosit o sarma tare ca sa prinda 'clanta' dinauntru...
de pe alt forum, din nou se pare 'experienta first hand' (daca ai ramas fara baterie la masina nu la telecomanda): "Am scos semnalizarea de pe lateral stanga (multumesc B50XXL) si am legat la soclul ramas liber ceva fire smulse dintr-un cablu de retea si legate la baterie. Astfel am alimentat jmecheria si am reusit sa deschid masina cu cheia "
RSS Lo-Fi Version Time is now: 7th October 2025 - 09:33 PM
