> E34 - OBC failure messages, Da, de acum am un E34!
reactor_share
post Mar 7 2009, 10:09 AM
64% BMW corupt
Car: E28
Engine: M21 524 TD 116CP
Salut.
Imi apare in bord:
LIC PLATE LIGHT
LOW BEAM
OWNNER's MANUAL
LOW COOLANT
BRAKE LININGS
TAIL LIGHT
Cateva le-am identificat, dar ce ma fac cu: LOW BEAM, OWNER's MANUAL, BRAKE LININGS, LOW COOLANT?
Posts in this topic
- reactor_share   E34 - OBC failure messages   Mar 7 2009, 10:09 AM
- - 316i   Low beam - ai un bec ars pe faza scurta, brake lin...   Mar 7 2009, 10:58 AM
- - reactor_share   Ei mi-am dat si eu seama de ce inseamna. Dar ce ma...   Mar 8 2009, 08:23 AM
|- - bartro   Gasesti usor pe vas senzorul, cred ca e ca la e32....   Mar 8 2009, 11:41 AM
|- - reactor_share   QUOTE (bartro @ Mar 8 2009, 11:41 AM) Gas...   Mar 8 2009, 08:51 PM
- - alex230ro   senzor bulit sau contacte oxidate asta inseamna da...   Mar 8 2009, 11:03 AM
- - florin83   dar un topic cu masina nu faci?   Mar 8 2009, 10:29 PM
- - reactor_share   Am sa fac dar dupa ce o inmatriculez! Multumes...   Mar 16 2009, 01:15 PM
- - reactor_share   brake LT circuit - un nou failure message. Am cau...   Mar 22 2009, 10:22 PM
|- - bartro   Poate sa fie cat un bec ars, sau cu un contact mai...   Mar 22 2009, 10:45 PM
|- - reactor_share   QUOTE (bartro @ Mar 22 2009, 10:45 PM) Po...   Mar 22 2009, 11:35 PM
|- - bartro   Te uiti la placute.. E posibil sa fie totul in reg...   Mar 22 2009, 11:48 PM
|- - florin83   QUOTE (bartro @ Mar 22 2009, 11:48 PM) Si...   Mar 23 2009, 12:10 AM
|- - bartro   QUOTE (florin83 @ Mar 23 2009, 12:10 AM) ...   Mar 23 2009, 10:43 AM
- - georgem   La E34 sigur stanga fata si dreapta spate sunt sen...   Mar 23 2009, 10:28 AM
- - reactor_share   Mai nou, dupa ce am mers cu 150-170 kmh, dar doar ...   Mar 30 2009, 08:54 PM
- - Ciupanezu   Ai verificat nivelul uleiului? Castrol 10W-40.   Mar 30 2009, 09:06 PM
|- - reactor_share   QUOTE (Ciupanezu @ Mar 30 2009, 10:06 PM)...   Mar 30 2009, 09:20 PM
|- - reactor_share   QUOTE (Ciupanezu @ Mar 30 2009, 10:06 PM)...   Mar 31 2009, 11:27 PM
- - Ciupanezu   Poate să consume ulei, este normal din moment...   Mar 30 2009, 10:47 PM
- - florin83   Eu din asta am pus!   Apr 1 2009, 08:58 AM
RSS Lo-Fi Version Time is now: 9th October 2025 - 11:01 AM
