Jan 24 2009, 04:26 AM
![]() 0% BMW corupt Group: Members Posts: 19 Joined: 22-January 09 From: galati Member No.: 2,470 Car: E36 Engine: 1,6 105 cp |
pls ...spuneti-mi si mie ce reprezinta cele 6 numere care apar la apasarea butonului de reset km si cheie la al 2-lea pct?...am facut cateva mii d km si alea au ramas tzapene....ce indica si cum ash putea s fac sa se mai schimbe;)
-------------------- dumb ass why are u screaming?it's the same till the end of time
Jan 24 2009, 11:04 AM
Nu sunt ultimele cifre de nr de sasiu sau ceva de gen?
Jan 24 2009, 07:58 PM
![]() 9% BMW corupt ![]() Group: Members Posts: 108 Joined: 16-February 06 From: Bucuresti Member No.: 193 Car: E36 Engine: M44 1.9 |
Instrument cluster test http://www.digest.net/bmw/archive/v8/msg10838.html 1st display: BMW PART NUMBER (6 digits) 2nd display: CODE NUMBER (5 digits) Internal Coding Plug # 3rd display: K NUMBER (4 digits) 4th display: CHASSIS NUMBER (5 digits) this is part of your VIN 5th display: SOFTWARE VERSION (3 digits) 6th display: REVISION INDEX (2 digits) Hardware # -------------------- Foste : E30 325ia, Smart ForTwo
Actuale : E36 318 ti; Jeep Grand Cherokee 4.7i |
Jan 25 2009, 06:19 PM
Instrument cluster test http://www.digest.net/bmw/archive/v8/msg10838.html 1st display: BMW PART NUMBER (6 digits) 2nd display: CODE NUMBER (5 digits) Internal Coding Plug # 3rd display: K NUMBER (4 digits) 4th display: CHASSIS NUMBER (5 digits) this is part of your VIN 5th display: SOFTWARE VERSION (3 digits) 6th display: REVISION INDEX (2 digits) Hardware # Eu pt 2nd display am 6 numere... 375044..... credeam ca e nr de km cand a fost resetat prima data bordul.... Ma gandeam ca BMW-ul meu are deja 600 000 de km.... This post has been edited by the_rifle: Jan 25 2009, 06:20 PM |
Jan 26 2009, 02:40 PM
oka...ms mult..ink ceva ...un update de soft s poate si tot odata ajuta la ceva?...akolo zice k asta e test 1....sincer cum ajungi la test 2.....si celelalte...mie nu imi scrie test 1 intra direct pe 1st display: BMW PART NUMBER (6 digits)
...un ajutor?sau poate nu este dotata mashina?... -------------------- dumb ass why are u screaming?it's the same till the end of time
Jan 26 2009, 09:30 PM
Teoretic se face asa: Step 1: Press and hold the mileage reset button. Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1) Your LCD display will show something like this "tESt 01" Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01," press the reset button till you get to "tESt 15." Once you're on test 15 press, and hold the reset button for a few seconds until it displays "off." Now you can cycle through the test features. Nu am incercat ptr ca momentan nu poci sa ies din casa din cauza unei glezne plesnite la schi. Dar am sa incerc pe al meu 318ti ptr ca ma intereseaza partea cu rezervorul deoarece la mine una din sonde bate campii. Daca reusesti ceva da de stire. -------------------- Foste : E30 325ia, Smart ForTwo
Jan 28 2009, 04:38 PM
sincer nu imi apare neam test 1 ....try si m anuntzi:D....poate e un alt dikis....mai nou abs is broken...mi-am skimbat cilindrii si sabotii p spate si mi-a intrat o eroare la abs...si nu imi mai mere...innebunesc:((
ai idee ???c e d facut?i-am curatat..si tot degeaba tre s ajung l un tester -------------------- dumb ass why are u screaming?it's the same till the end of time
Feb 3 2009, 04:23 PM
Teoretic se face asa: Step 1: Press and hold the mileage reset button. Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1) Your LCD display will show something like this "tESt 01" Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01," press the reset button till you get to "tESt 15." Once you're on test 15 press, and hold the reset button for a few seconds until it displays "off." Now you can cycle through the test features. Nu am incercat ptr ca momentan nu poci sa ies din casa din cauza unei glezne plesnite la schi. Dar am sa incerc pe al meu 318ti ptr ca ma intereseaza partea cu rezervorul deoarece la mine una din sonde bate campii. Daca reusesti ceva da de stire. am ajuns si la tester....mi-a conectat testerul....mi-a sters eroarea...mi-a curatzat senzorul si....am facut o tura prin parkrea lor..am platit 100 ron si ce s vezi...dupa c am plekt la 2 km am pus frana mai brusk si ce s vezi...a aparut iar martoru...shit.....deci cine are vreun senzor d vanzare?... k nea sh cere o gashk d bani:(((((((( app..ce ai mai facut ai gasit Christache smekeria?ti-a trecut piciorul;??? -------------------- dumb ass why are u screaming?it's the same till the end of time
Feb 10 2009, 01:45 PM
La mine functioneaza.Am incercat astazi si merge.
Deci : cu cheia la poz 0 tii apasat pe butonul de reset km, pui contactul si apare ceva cu test 01 - dai drumu la buton reset si apesi pe el scurt si dai drumu - in momentul asta display ar trebui sa arate test 02 - tot asa pana la test 14 numai ca dupa test 14 apesi pe buton si tii apasat - in momentul asta trece pe 15 si dupa 3 secunde tinut apasat ar trebui sa ai deblocat restul de teste de la 5 la 14. Nu sunt cine stie ce mare branza oricum, eu doar am vrut sa verific daca intr-adevar bate campii sonda de benzina si mi-a confirmat ca bate rau -------------------- Foste : E30 325ia, Smart ForTwo
Feb 10 2009, 08:18 PM
La mine functioneaza.Am incercat astazi si merge. Deci : cu cheia la poz 0 tii apasat pe butonul de reset km, pui contactul si apare ceva cu test 01 - dai drumu la buton reset si apesi pe el scurt si dai drumu - in momentul asta display ar trebui sa arate test 02 - tot asa pana la test 14 numai ca dupa test 14 apesi pe buton si tii apasat - in momentul asta trece pe 15 si dupa 3 secunde tinut apasat ar trebui sa ai deblocat restul de teste de la 5 la 14. Nu sunt cine stie ce mare branza oricum, eu doar am vrut sa verific daca intr-adevar bate campii sonda de benzina si mi-a confirmat ca bate rau pls baga un filmuletz k eu sunt mai dimb poate kiar nu are al meu dar poate imi vei arata tu pls....da un filmuletz p mail pe rog...panteralovesyou@yahoo.com...sau pune-l aici ..........plsssssssssssssssss -------------------- dumb ass why are u screaming?it's the same till the end of time
Lo-Fi Version | Time is now: 27th October 2025 - 10:31 PM |
