2 Pages V  < 1 2
> bobina separat pe fiecare cilindru
Darren
post Nov 11 2005, 03:28 PM
Post #21
Car: E36 318i/1995
Engine: M43 1.8 115CP
Nush unde ai citit tu, dar la mine scrie asa:
"Plasma BOOSTER™
The Plasma Booster™ is a revolutionary Ignition component to enhance existing INDUCTIVE type ignition systems from distributor ignition to single coil applications and everything in between, including waste spark ignition.
Highlights
• Easy to install, only 2 wires on distributor type ignition.
• 100% secondary current (Spark Amperage) increase
• 4 Times Spark Energy Increase for the initial spark discharge
• Compatible with all OEM components
• Compatible with OBD-II (On-Board-Diagnostics)
Comparison between OEM and Plasma Booster Ignition
OEM Ignition System
Secondary spark voltage measured on the secondary discharge in to the spark.
Notice the single ionization spark and a long duration of low voltage spark.
See details under Technical Section, or click here.
Same secondary spark voltage measured on the same secondary discharge with the Plasma Booster installed.
Notice the Multiple Spark Discharge of about 10 Sparks within 500 micro seconds of the total spark.
Plasma Booster™ comes in 6 different versions for many different applications. Please look under applications to find the correct model for your ignition."
Iulika0069
post Nov 12 2005, 08:39 AM
Post #22
Engine: S50 turbo 400+WHP
Rabanne
post Nov 21 2005, 02:25 AM
Post #23
18% BMW corupt
Cea mai simpla solutie este iei instalatia de pe un motor M50 si sa iei si motorul sa le montezi impreuna pe masina:)NU vad rostul in a monta bobine pe fiecare piston atata timp cat exista chiptuning pe masina ta pentru ca pana una alta chiptuningul iti modifica gradajul avansului lucru mult mai eficient decat marirea puterii scanteii:)Chiar...cine imi explica pe aici dc s-au montat pe M50 6 bobine?:)Barrriton?
Zom
post Nov 21 2005, 08:59 AM
Post #24
toate motoarele cu aprindere gestionata electronic au bobina pe fiecare cilindru tongue.gif
de ce, de ce.... asa au zis ei ca e mai bine, ca mai castiga putere... doar n-am fost in capul lor...
Rabanne
post Nov 21 2005, 10:29 AM
Post #25
18% BMW corupt
CRed ca s-a cautat mai mult fiabilitatea nu puterea:)
Zom
post Nov 21 2005, 11:00 AM
Post #26
QUOTE (jaffar)
QUOTE (barrriton)
fals... vezi motronic 1.{0,1,3}
fie,cu mici exceptii...
vico
post Nov 21 2005, 03:44 PM
Post #27
Principalul avantaj al modificarii consta in eliminarea distribuitorului.
Principial, e destul de simplu: semnalul de aprindere (din primarul bobinei de inductie) se formateaza si se introduce intr-un numarator/divizor cu 6 (sau 2 pentru M10/M40 si Wasted Spark). La iesirile numaratorului se conecteaza primarul bobinelor.
Pentru siguranta, numaratorul se reseteaza la fiecare ciclu motor.
Avantaje: distributorless biggrin.gif
fiabilitate crescuta
Dezavantaje: costuri - la 4 cilindri sunt rezonabile, se pot folosi bobinele de Alfa 33
MARI probleme daca nu e foarte bine realizat si ecranat montajul si ajunge sa dea scanteie alandala
In concluzie - o modificare foarte interesanta dar nu e la indemana amatorilor.
Rabanne
post Nov 21 2005, 10:15 PM
Post #28
18% BMW corupt
Interesanta dar cam inutila pe M20 care este si asa destul de fiabil:)
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 8th October 2025 - 07:39 AM
