5 Pages V  « < 3 4 5
> Viforul, Honda VFR 800 fi
post Jun 11 2020, 12:44 PM
Post #81
In caz ca n-am mai pus link-ul aici:
Demontare pompa benzina, zice ceva si de maf care de fapt o fi map?
https://www.youtube.com/watch?v=oFHhAuAiPRE&t=902s
Si mai zice cineva sa vad daca pot regla TPS cu cheia de 10.
Pai sa incercam!
post Jun 13 2020, 10:49 AM
Post #82
QUOTE (TiL @ Jul 20 2019, 06:07 PM) *
Sa nu uit:
4 Suruburi mari de panou
Cele de pe burta – plastic, clips, etc
2 clipsuri interior fata
1 piulita cauciucata de panou M5
2x Piulita sus panou M6 plus suruburi
2 x Surub si piulita codita sus
Support racorduri frana spate
Ureche prindere lower cowl right side
Clipsuri de prindere capace computer si baterie - total 6 buc.
post Jun 18 2020, 12:43 AM
Post #83
ORDER IS PAID
Purchase US $179.17
Delivery from Japan US $27.51
Discount US -$22.96
TOTAL COST US $183.72
Package №385487-1-1 (Japanese Warehouse)
Not Shipped
Handling Time 3...5 business days
Shipping Time 5...10 business days
Estimated Between Jun 30...Jul 9
Delivery method Express Mail Service (EMS)
Cover, Honda
32414-MW0-000 US $4.14 1 pc. US $4.14
Gasket, muffler, Honda
18391-ML0-003 US $19.75 2 pcs. US $39.50
Stay, fr. side cowl, Honda
64511-MBG-000 US $6.03 1 pc. US $6.03
Bolt, cowl setting, Honda
90112-MT4-000 US $2.33 4 pcs. US $9.32
Clip, trim, Honda
90683-GAZ-003 US $1.96 11 pcs. US $21.56
Screw, pan (5x20), Honda
90103-MBG-000 US $1.36 8 pcs. US $10.88
Nut (5mm), Honda
90111-KW3-003 US $2.48 8 pcs. US $19.84
Clip *nh1*, Honda
91549-MW0-790ZA US $2.33 2 pcs. US $4.66
Label,tire, Honda
87505-MBG-600 US $4.83 1 pc. US $4.83
Label, drive chain, Honda
87507-MZ8-W00 US $4.07 1 pc. US $4.07
Cap, rr. axle, Honda
42303-MT4-000 US $5.43 1 pc. US $5.43
Label, Honda
87508-MT4-300 US $2.33 1 pc. US $2.33
Bolt, rr. cowl hook, Honda
90116-MBG-000 US $14.31 2 pcs. US $28.62
post Jun 18 2020, 04:36 PM
Post #84
Intre timp m-am jucat cu sincronizarea admisiei la relanti.
Le-am nivelat frumos, dupa care am deschis manualul si am aflat ca la VFR nu se niveleaza smile.gif) Si ca trebuiesc infundate iesirile de pe capacele de la culbutori catre PAIR valve (un fel de PCV?)
Am desigilat si pozitia TPS, l-am mutat f putin spre amestec sarac.
Am masurat apoi senzorii MAP, Baro si TPS, cu ace infipte in conectorul computerului de injectie. Au iesit toti in parametri:
- pentru MAP si Baro estimam ca ar trebui sa dea cam 2,9V aici la campie. Au iesit la 2,88 si 2,87.
- TPS: 0,45V cu clapetele inchise si 4,5V cu ele deschise la maxim. Range-urile acceptate sunt: 0,45 - 0,55 V cu 3,7 - 4,5 V . De fapt depinde unde te uiti in manual, ca mai e un loc care spune 0,4 - 0,6 cu 4,2 - 4,8.
Deci la TPS am picat la fix ca sa fie in range la ambele capete.
Merge mai frumos, schimba mai smooth intre tractiune si frana de motor. Inca miroase intepator la curu ei.
Acum vreau sa sincronizez ca la carte, dar intai sa pun "noua" toba. Am spalat toba interior-exterior cu motorina si peria de sarma, am clatit cu diluant, am rupt garnitura de esapament, ca intra cam fortat si auzisem ca astea sport se pun fara garnitura. Cel putin asa-i la Delkevic pe VFR800, Mivv pe GPZ, etc.
post Jul 23 2020, 10:18 PM
Post #85
400 de lei mai tarziu, au venit piesulicile de la Mivv, montat toba, sincronizat ca la carte (1 si 2 la nivel, 3 cu vreo 32cm coloana de ulei mai jos, 4 cu 15cm sub), poate maine fac o proba.
Bateria s-a descarcat, avea doar 9V dupa o luna, deci o sa mai tina cel mult sezonul asta.
post Jul 24 2020, 05:29 PM
Post #86
Am mai reglat nitel dupa ce am pus la loc furtunele pe capacele de culbutori.
Montat si tot felul de surubele si piulite care erau lipsa ori inlocuite cu niste improvizatii, clipsuri de plastic pe la carene, capac de computer, capac de baterie. Suruburi noi ici-colo unde cele vechi erau prea uzate.
Acu-i completa.
post Aug 17 2020, 05:46 PM
Post #87
Mivv duduie cam tare. In regim de mers lejer in oras, duduie bine in casca.
Sunt curios cum se aude de afara, dar banuiesc ca e cam deranjanta. Asa, pe DN, suna ca o masina de Nascar biggrin.gif
O sa-i montez dbkillerul cumparat nou, dar care nu e prevazut cu surubul de prindere. Improvizez unul.
Urmeaza o vacanta de 1000km, ma gandesc daca merg cu Honda sau cu X5. Tentant rau motorul, dar parca as lua butoiul ambulant, ca sa intre toate bagajele mai mult sau mai putin utile.
post Aug 18 2020, 10:10 AM
Post #88
Si Guzzi bubuie in casca (parca ai mers un pic pe ea), dar in mers nu e asa rau pentru restul lumii. Se mai aude tare in pasaje, spatii inchise.
post Nov 11 2020, 12:02 PM
Post #89
Asa, de curiozitate
Attached File(s)
Attached File  RAR_istoric_vehicul_VFR.pdf ( 6.11K ) Number of downloads: 366
post Aug 9 2021, 05:50 PM
Post #90
61000 km
Merge dupa cum ma simt eu. Cand sunt in forma merge brici, cand sunt prea obosit abia o tin pe drum.
Ar trebui sa schimb uleiul, il simt cam alterat, are 5000km, schimbat in urma cu un an si 5 luni.
Si un service complet: rulment jug, service furca, disc spate, gume fata-spate.
Saptamana trecuta am alergat prin Dobrogea (tura in Vama - Isaccea - Mamaia si retur spre casa). WE anterior fusesem la Zarnesti cu valizele pe ea, pentru o tura de o zi pe munte. La fel si WE care tocmai s-a incheiat.
Tot asa si acum patru saptamani, la Simon.
post Jun 27 2022, 10:39 AM
Post #91
Am mai mers putin cu ea in Martie-Aprilie. Acelasi mers bogat. Daca pun dbkiller, chiar merge urat, cam inecat.
Fara Db Killer e mai elastic, mai vioi.
Shopping list:
- disc frana spate
- placute frana spate
- rulmenti roata fata
- rulment jug
- kit furca?
+ discuri frana fata
+ placute frana fata.
Parca atat, deocamdata.
post Jul 1 2022, 12:27 PM
Post #92
Montat cauciuc spate Metzeler Sportec M9 RR cumparat in urma cu un an si ceva. Dunlop de pe fata e inca ok, poate la anul ii pun tot un Sportec.
N-am cum sa echilibrez roata spate pe standul de echilibrat roti moto, dar din incercari repetate diferite, pare ca asa cum e acum, cu plumbii vechi, e ok.
Trebuie sa gasesc o vulcanizare cu ax subtire la masina de echilibrat.
Desfacut si uns bine cu spray white grease blocul de lumini care-mi tot ura sudden deadh.
La revenirea de pe faza lunga pe scurta nu prea mai aprindea faza scurta, lasandu-ma in bezna.
Acum pare sa fie ok, vedem la drum daca vedem sau... nu.
Intins lantul, uns bine, facut RCA si-i gata de drum.
post Aug 10 2022, 06:24 PM
Post #93
post Apr 23 2023, 09:57 PM
Post #94
Maine dau sala pentru CE si m-as duce cu motorul, cei 105km pana la Judet.
Cred ca dupa plimbarea din August nu am mai miscat-o. A ramas cu mustele lipite si cu rezervorul cam gol.
Bateria rezista eroic, desi nu era tocmai noua cand am luat motorul, i-ar de-a lungul timpului am mai scapat-o descarcata in garaj, in timpul iernii. Iarna asta am incarcat-o de cateva ori, o data de la zero, in rest preventiv, de la 10-11V.
Am curatat filtrul de aer, avea ceva nisip.
Inca n-am schimbat uleiul, era bine sa-l schimb inainte de tura de maine, dar...
BBo
post Apr 24 2023, 02:43 PM
Post #95
91% BMW corupt
Car: E30|E46
Engine: M20|M54
Recomanzi/recomandati vreo scoala moto in Bucuresti? Sau instructor personal etc?
post Apr 26 2023, 04:15 PM
Post #96
Scoala Moto Iancu
- by Eugen Iancu
https://www.scoalamotoiancu.ro/
https://www.facebook.com/profile.php?id=100064243833614
Atentie, cea a lui Eugen Iancu, de pe Ion Ionescu de la Brad
Eu am facut cand inca nu se despartise de scoala pe care o au tatal+fratele lui, dar am avut noroc sa-l nimeresc pe Eugen ca instructor.
Daca ai soricul gros si tii la vorbe grele, o sa scoata motociclist din tine, oricat de fricos sau lipsit de talent ai fi.
L-am recomandat si unei tipe care era nitel traumatizata dupa un accident urat avut pe poligonul aglomerat de la Obor/Electronicii. Fiind si ea un caracter puternic, nu i-a indurat foarte mult atitudinea dura, s-a mutat inapoi la scoala ei din Obor, dar o spune si acum ca el a facut motociclist din ea.
Intre timp am uitat sa merg cu motorul, ori e pentru ca trec si printr-o pasa mai proasta. Dar a fost ok, la dus i-am dat nitel bice ca eram in intarziere, la intoarcere mers lejer.
Consum 5,45.
Am comandat ulei, cred ca filtru aveam de ceva vreme, poate le schimb in WE.
post Sep 27 2023, 07:23 PM
Post #97
63800 km
Ulei Wolf 5W50
Filtru Mann
3 ani si jumatate si 7600 km de la ultimul schimb.
Completat cu apa distilata, era pe la nivelul minim.
Inca are nevoie de cele enumerate mai sus. Discuri fata spate, placute, rulment jug si investigat mersul bogat. A, si pinioane plus lant, ca am pus eu lant nou cand am luat-o, dar se intinde in valuri inca de atunci.
5 Pages V  « < 3 4 5
RSS Lo-Fi Version Time is now: 8th October 2025 - 02:50 PM
