4 Pages V   1 2 3 > »
> Schimbare diferential open cu unul LSD
Iulika0069
post Feb 28 2006, 08:28 PM
45% BMW corupt
Car: E30
Engine: S50 turbo 400+WHP
Intrebarea e in primul rand pt E36, dar se poate extinde la toate modelele..
Ma intereasa pareri, fapte de opinie, link-uri.. orice informatie care sa ma lumineze
Unii zic ca nu conteaza ce ulei pui (75W90), nu e diferit de cel care se pune in diff-urile "normale"
Altii zic ca tre' sa scrie pe cutie "pt LSD"
Cativa ma indruma (corect biggrin.gif) catre "reprezentanta" BMW
So, care e raspunsu' corect?
Iulika0069
post Feb 28 2006, 08:38 PM
45% BMW corupt
Car: E30
Incep io cu ce am gasit pe net:
"BMW have issued a Service Bulletin (i think it was in '93, i can look up the bulletin if anyone needs it) that stipulates new synthetic final drive lubricants for all BMW models.
There are two types of oil, depending on if you have a standard 'open' diff or a Limited Slip diff (LSD).
Oils for standard (open) diffs:
BMW Synthetic OSP
Castrol SAF-XO
Oils for Limited Slip diffs:
BMW Synthetic MSP
Castrol SAF-XLS
[unknown brand] VS-700"
http://www.bimmerworld.com/html/redline-gear-oil.htm
http://www.dol.net/~stimpee/rdiff.htm
GL4 sau GL5?
http://www.sas-gmbh.de/BP-Schmierstoffe/getriebe/
Gabi_323i
post Mar 1 2006, 10:56 AM
82% BMW corupt
Car: E21
Engine: M20 2.3 143CP
iei ulei de diferential full sintetic
BMW E21 323i 2.3l K-Jetronic, 17" Alpina
316i
post Mar 1 2006, 03:20 PM
Road Runner
Car: BMW E30 08/90
Engine: 08/94 M42 318iST
Eu am pus Mobil 80W90...o fi bun? :paranoid:
16 valves, 24 hours a day, 1bar boost. A vulgar display of power. Making boost since 30-06-2008.
316i
post Mar 1 2006, 09:35 PM
Road Runner
Car: BMW E30 08/90
de ce?
Gabi_323i
post Mar 1 2006, 10:22 PM
82% BMW corupt
Car: E21
75w90
Iulika0069
post Mar 1 2006, 10:58 PM
45% BMW corupt
Car: E30
La sfatul maxi-technixului Jaffar, am fost la BMW Otopeni si am luat ulei special de LSD (o sa ma uit pe factura sa vad cum ii zice ca nu mai stiu biggrin.gif) => 11E+VAT / litru, vreo 95RON 2l
Ca sa nu mai fac inca un topic, o sa prezint pas cu pas cam ce am facut:
Iulika0069
post Mar 1 2006, 11:08 PM
45% BMW corupt
Car: E30
Din pacate insa ne-am lovit de o problema (minora biggrin.gif): flansele dela planetare - cele depa LSD - nu erau ale lui :|, asa ca le-am luat pe cele "originale"
Se scot f. usor, o lovitura scurta si ies depe semeringuri - nu au nici o piulita
Desi se potriveau la gauri, am ales sa interskimbam si flansele dela cardan
Aici a fost mai greutz, exista o siguranta de metal si o piulita de 36 care prinde flansa respectiva
Piulita s-a montat cu cheia dinamometrica, nu am intrebat la ce cuplu, dar a fost un semn de profesionalism biggrin.gif
Iulika0069
post Mar 1 2006, 11:14 PM
45% BMW corupt
Car: E30
Practic, flansele dela planetare depe LSD nu aveau nici o treaba cu el, cred ca sunt depe un seria 5 (tipul mai are un LSD de 5er, asa ca cine e interesat..)
Iulika0069
post Mar 1 2006, 11:19 PM
45% BMW corupt
Car: E30
S-a demontat doar bara stabilizatoare spate (si bineinteles piulitele dela planetare si cardan biggrin.gif)
mertan
Car: e30
Engine: m20 2.0 129CP
cadn pun lsd-ul meu vreua sa schimb uleiul.care este bun? ce indicativ?
316i
post Mar 1 2006, 11:25 PM
Road Runner
Car: BMW E30 08/90
mertan>Pana la urma al tau e LSD?
Iulika0069
post Mar 1 2006, 11:29 PM
45% BMW corupt
Car: E30
Mertan, o sa pun codul maine, dar in principiu io as lua dela BMW
E cam acelasi pret (<500.000/l) cu un Mobil 75W90
Le-am cerut niste detalii tehnice (vascozitati) dar nu au stiut sa imi zica smile.gif
In final m-a dus aproape de 250E, dar merita fiecare banut!!! biggrin.gif biggrin.gif biggrin.gif :unibrow: :unibrow: :unibrow:
akajohn
post Mar 1 2006, 11:30 PM
27% BMW corupt
Car: e46 316i
Engine: M43B19 1895 cmc 105 CP
ce e ala LSD? hai baieti bagati explicatii... smile.gif merge pus asa ceva pe e46 daca e asa bun #-o
Gabi_323i
post Mar 1 2006, 11:32 PM
82% BMW corupt
Car: E21
limited slip diferential
mertan
post Mar 1 2006, 11:38 PM
Post #16
Car: e30
mai frate. tehnic e lsd. dar pe dinafara nu se vede. pe placutze nu scrie S. sa mor eu daca stiu. dar il montez. si va arat dacae.
florin83
Post #17
Group: Root Admin
Car: E36 325i
Engine: M50 192CP
fara lsd (mai mult ca sigur n-ai tongue.gif) daca o roata e pe gheata si una pe ciment nu mai pleci de acolo ca toata puterea e transmisa pe roata care da in gol..
mertan
post Mar 1 2006, 11:42 PM
Post #18
Car: e30
sa mor eu daca inteleg fenomenul. sunt pe ghiatza da? una pa asfalt. si accelerez.e ... la lsd. se invart amandoua odata. nu e 50%putere pe ghiata si 50% pe asfalt?
Gabi_323i
post Mar 1 2006, 11:45 PM
Post #19
82% BMW corupt
Car: E21
da ba frate, e pe ghiata
florin83
post Mar 1 2006, 11:47 PM
Post #20
Group: Root Admin
Car: E36 325i
Engine: M50 192CP
mosheta pe ghiata, ce te bagi? :finger:
nu stiu nici eu pana la cat % se transfera stanga dreapta, cred ca e in functie de diferential...
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 18th September 2025 - 01:24 AM
