Jul 25 2010, 07:55 PM
0% BMW corupt Group: Members Posts: 2 Joined: 25-July 10 Member No.: 3,467 Car: e30 cabrio Engine: m20 b20 129cai |
- parbriz original bmw + cheder 150 ron
-luneta + cheder 70 ron - geamuri coupe 88> 50 ron buc - geamuri sedan 86 40 ron buc -baie ulei 6 pistoane m20 150 ron -panou spate 90 + stopuri =150 ron -amort sport reglabile fata pt jambe groase 200ron -amort sport spate 150 ron -arcuri fata spate stock 100 ron -motor 20 12v jetronic complet 600 ron -motor 25 12v motronic complet 1000 ron -caroserie coupe cu acte 1000ron -bloc motor m20 b20 motronic adus germania 400 ron -faruri simple de 86 -100 ron set -motoras stergatoare -50 ron -instalatie electrica cu check control -150 ron -jambe normale fata cu fuzete 200 ron -pompa benzina rezervor -150 ron -pompa benzina exterior -150 ron -plutitor 50 ron -butoane , chedere , plastice -20 ron -caseta directie manuala 150 ron -caseta servo directie 300 ron -stopuri late 100 ron perechea -debitmetru 2000 12v jetronic 100 ron -admisie 20 12v motronic completa 200 ron -instalatie motor 2000 12v motronic 100 ron jetronic 100ron -capac delcoo motronic impecabil 200 ron -oglnizi 100 ron set completa -bara spate e36 + armatura + tampoane 150ron -discuri duble + etrieri de e36 150 ron -senzori abs 50 ron buc -tapiterie plafon 4 usi -50 ron -bara fata spate de 90 complete 100 ron buc -jambe groase - -tapiterie plafon cu trapa coupe schimb si cu alte piese , am nevoie de --caucicuri pe 16 40 45 195 205 215 -statie 300 w real cu 125 decibeli pt woofer -diferential simplu sau blocant -manivela trapa -prezoane lungi -distantiere -flanse distantiere 0766741725 0728471116 id mess alexutzu_88_alex |
Jul 31 2010, 12:20 AM
vezi ca ai gresit sectiunea!
rog un moderator sa mute acest topic unde-i este locul -------------------- "PUTEREA BATE CUPLU PT CA TOT TIMPUL VEI GASI O TREAPTA INFERIOARA UNDE SA O PUI"
Nov 15 2010, 06:21 PM
18% BMW corupt ![]() Group: Members Posts: 251 Joined: 18-November 08 From: Bucuresti Member No.: 2,335 Car: E21 Engine: M10 1.8 98CP |
- parbriz original bmw + cheder 150 ron -luneta + cheder 70 ron - geamuri coupe 88> 50 ron buc - geamuri sedan 86 40 ron buc -baie ulei 6 pistoane m20 150 ron -panou spate 90 + stopuri =150 ron -amort sport reglabile fata pt jambe groase 200ron -amort sport spate 150 ron -arcuri fata spate stock 100 ron -motor 20 12v jetronic complet 600 ron -motor 25 12v motronic complet 1000 ron -caroserie coupe cu acte 1000ron -bloc motor m20 b20 motronic adus germania 400 ron -faruri simple de 86 -100 ron set -motoras stergatoare -50 ron -instalatie electrica cu check control -150 ron -jambe normale fata cu fuzete 200 ron -pompa benzina rezervor -150 ron -pompa benzina exterior -150 ron -plutitor 50 ron -butoane , chedere , plastice -20 ron -caseta directie manuala 150 ron -caseta servo directie 300 ron -stopuri late 100 ron perechea -debitmetru 2000 12v jetronic 100 ron -admisie 20 12v motronic completa 200 ron -instalatie motor 2000 12v motronic 100 ron jetronic 100ron -capac delcoo motronic impecabil 200 ron -oglnizi 100 ron set completa -bara spate e36 + armatura + tampoane 150ron -discuri duble + etrieri de e36 150 ron -senzori abs 50 ron buc -tapiterie plafon 4 usi -50 ron -bara fata spate de 90 complete 100 ron buc -jambe groase - -tapiterie plafon cu trapa coupe schimb si cu alte piese , am nevoie de --caucicuri pe 16 40 45 195 205 215 -statie 300 w real cu 125 decibeli pt woofer -diferential simplu sau blocant -manivela trapa -prezoane lungi -distantiere -flanse distantiere 0766741725 0728471116 id mess alexutzu_88_alex salut mai ai nevoie de distantiere... daca te intereseaza, anunta ma k vreau si eu ceva din lista ta. |
Lo-Fi Version | Time is now: 26th October 2025 - 10:57 PM |
