#81
0% BMW corupt Group: Members Posts: 6 Joined: 31-October 09 Member No.: 3,034 Car: E36 Engine: MB43 1.6 ![]() |
Vad un 325I e36 in titlu, ma intereseaza ce model e coupe/cabrio/sedan ce cutie de viteze are (automata/manuala) si ce tip de climatizare are (manual/automat) ? Mersi
#82
18% BMW corupt ![]() Group: Members Posts: 189 Joined: 21-August 08 Member No.: 1,751 Car: E36 Engine: E36 2.5 192CP ![]() |
#83
#84
#85
0% BMW corupt Group: Members Posts: 87 Joined: 6-April 10 Member No.: 3,336 Car: E28 E30 E36 Engine: M20b25 M43 M50 M52b25 ![]() |
tragar e36+grila completa+bara fata+aripa dreapta de sedan am si eu nevoie.rog pm
#86
#87
![]() 27% BMW corupt ![]() ![]() Group: Members Posts: 323 Joined: 23-August 06 From: Bucuresti Member No.: 430 Car: E36 coupe Engine: M50B25 192cp ![]() |
Ma intereseaza volanata , placa de presiune , elctromotorul (poate fi si ars ) si eventual discul de ambreiaj... de pe motor M30 ( E12 , E23 , E24, E28 , E32)
Da-mi PM |
#88
Ma intereseaza volanata , placa de presiune , elctromotorul (poate fi si ars ) si eventual discul de ambreiaj... de pe motor M30 ( E9 E12 , E23 , E24, E28 )
Ma intereseaza volanta masa dubla de 240X27 .... Nu cumpar 240X33 S-a pus pe urmatoarele modele : http://bmwfans.info/parts/catalog/11221270286/ Date tehnice la : http://bmwfans.info/parts/catalog/E28/Seda..._mass_flywheel/ Piesa nr 8 codul 11 22 1 270 286 Part Cross-reference RealOEM.com Home Language: Part 11221270286 (Flywheel) was found on the following vehicles: E12: Details on E12 E12 528i Sedan, USA E12 530i Sedan, USA E12 525 Sedan, Europe E12 528 Sedan, Europe E12 528i Sedan, Europe E12 535i Sedan, Europe E23: Details on E23 E23 733i Sedan, USA E23 728 Sedan, Europe E23 728i Sedan, Europe E23 728iS Sedan, Europe E23 730 Sedan, Europe E23 733i Sedan, Europe E23 735i Sedan, Europe E24: Details on E24 E24 630CSi Coupe, USA E24 633CSi Coupe, USA E24 628CSi Coupe, Europe E24 630CS Coupe, Europe E24 633CSi Coupe, Europe E24 635CSi Coupe, Europe E28: Details on E28 E28 525i Sedan, Europe E28 528i Sedan, Europe E9: Details on E9 E9 2800CS Coupe, USA E9 3.0CS Coupe, USA E9 2.5CS Coupe, Europe E9 2800CS Coupe, Europe E9 3.0CS Coupe, Europe E9 3.0CSi Coupe, Europe E9 3.0CSiL Coupe, Europe E9 3.0CSL Coupe, Europe |
#89
nu mai am de m30 imi pare rau
#90
#91
#92
#93
#94
18% BMW corupt ![]() Group: Members Posts: 251 Joined: 18-November 08 From: Bucuresti Member No.: 2,335 Car: E21 Engine: M10 1.8 98CP ![]() |
contact + incuietoare + cheie??? e30 This post has been edited by fistaccio: Aug 17 2011, 09:26 PM |
#95
am contact e 30,cu incuietoare si cheie...
#96
Am nevoie de mufele alea doua care intra in bordul cu ceasuri la E30, cea alba si cea albastra, cu tot cu cate o bucatica de cablu, cat de lunga se poate, sa am pe ce face lipituri. Pret?
#97
pompa de injectie de 2.4td?
#98
este pompa e inj. |
#99
#100
am ceasuri
Lo-Fi Version | Time is now: 7th October 2025 - 10:42 AM |
