Nov 6 2009, 05:46 PM
Vand Sistem Blaupunkt GTB300-GTA270 in stare foarte buna , folosit maxim 3-4 luni pentru ca mai mult am carat cu masina.Se poate proba fara probleme
Pret 400 ron Tel 0723312192 sau mail 2/1-Channel class A/B Amplifier Max. Power 2x150 Watts/ 1x400 Watts (4 Ohms), 2x200 Watts (2 Ohms) RMS Power 2x70 Watts/ 1x200 Watts (4 Ohms), 2x100 Watts (2 Ohms) Frequency response 10 - 26000 Hz Signal to noise ratio > 90 dBA Distortion factor < 0.04 % Input impedance >10 kOhm Attenuation factor > 100 Input sensitivity 0.3 - 8 V Stability 2 Ohm (4 Ohm bridged) Low-pass filter 50 - 250 Hz (12dB/Oktav) High-pass filter 50 - 250 Hz (12dB/Oktav) Bass Boost 0 - 12dB at 45 Hz Inputs 2x RCA gold plated Outputs 2x loud speakers, gold plated Line-Out 2x RCA gold plated Dimensions (WxHxD in mm) 200 x 49 x 254 Diameter 300 mm Max. Power 750 Watts RMS Power 250 Watts High sound pressure level 91 dB (2.83 V/m) Frequency response 35 - 500 Hz Impedance 4 Ohm Membrane material SPC Dimensions (WxHxD in mm) 482 x 387 x 378[attachment=27790:194.88.148.40.htm] This post has been edited by Sorin: Nov 6 2009, 05:52 PM -------------------- To the aiiiiiiirport
Lo-Fi Version | Time is now: 29th October 2025 - 11:57 AM |
