> PIESE AUTO, LUBRIFIANTI AUTO, ACCESORII AUTO & TUNING, PIESE AUTO, LUBRIFIANTI AUTO, ACCESORII AUTO & TUNING
enculescusorin
post May 19 2009, 08:28 PM
beemwe - ist
Car: 320i E36 coupe
Engine: m50b20 S2
PIESE AUTO, LUBRIFIANTI AUTO, ACCESORII AUTO & PRODUSE TUNING, o sa postez in curand si cateva preturi pt produsele comercializate de noi :
Lubrifianti auto & moto ( aftermarket si oem ) - Castrol, Mobil1, Motul, Esso, Liqui Moly, Meguin, BMW OEM, OPEL OEM, FORD OEM, VW OEM, MERCEDES OEM
- Piese auto - la fel, de la repere aftermarket pana la oem, in principiu livram orice piesa incepand de la masini clasice pana la camioane man, ambarcatiuni, etc.
- Produse tuning de la BOSAL, MAFEX, H&R, BILSTEIN, BREMBO, ZIMMERMAN, EBC, K&N etc.
In curand o sa fie disponibil si site-ul pentru cumparaturi on-line : www.elsoautomotive.com
Membrii www.bmwzone.ro beneficiaza de discounturi incepand de la 10 pana la 30 %.
This post has been edited by sierra1771: May 19 2009, 08:31 PM
enculescusorin
post May 20 2009, 07:25 PM
beemwe - ist
Car: 320i E36 coupe
Engine: m50b20 S2
up.... ulei BMW OE, 5w30 - 35 lei / litru, 5w40 - 27 lei / litru...
This post has been edited by sierra1771: May 20 2009, 07:40 PM
enculescusorin
post May 23 2009, 12:51 PM
beemwe - ist
Car: 320i E36 coupe
Engine: m50b20 S2
up
mario.b
post May 25 2009, 11:47 PM
Engine: M20 2.0 93kW
discuri fata perforate & ventilate + placute de frana pt e36 318is coupe gasim
enculescusorin
post May 28 2009, 07:44 PM
beemwe - ist
Car: 320i E36 coupe
Engine: m50b20 S2
CITAT(mario.b @ May 26 2009, 12:47 AM) *
discuri Zimmermann + placute ferodo DS te ajung undeva la 1200 de lei,daca vrei am si brembo sau ebc, scuze de intarziere.
elvislorin
post Feb 16 2010, 08:36 PM
Cazan owner
Engine: M50B25 192 CP
up...preturi bune....si la uleiuri, filtre, piese aftermarket si oem...
post Apr 19 2010, 11:46 AM
Roadrunner
Engine: M57D30
ulei Mobil SCH 630 pentru cutii de viteze ai la recipient mai mic de 20L ?
post Apr 19 2010, 11:52 AM
Roadrunner
Engine: M57D30
si ceva date despre uleiul BMW cu part numberul 81 22 9 407 305 (denumirea mai sus - Mobil...) :
EN -
4.0 Transmission oil for transmissions with green label
Kod: Zaznacz wszystko
Note:
The green label with the words "Special Oil!" is located next to the oil filler plug.
Tradename BMW part number Container size
Manual transmission oil 81 22 9 407 305 20-litre canister
Note:
To reduce the physical effort required to change gear at low ambient temperatures, the following oils can be used in the transmission during the winter:
- Single-grade, heavy-duty, mineral-based engine oils, SAE40, SAE30, SAE20
- In countries with particularly low ambient temperatures, ATF oils (please refer to Enclosure 3.0) may also be used. This has the disadvantage that the transmission tends to rattle or knock while in neutral at higher temperatures.
Attention!
These transmissions must never be filled with synthetic engine oils or multigrade engine oils, since these oils contain coefficient of friction reducing agents which can adversely affect operation of the synchromesh
mechanism.
DE:
4.0 Getriebeöl für Getriebe mit grünem Aufkleber
Hinweis:
Der grüne Aufkleber mit der Aufschrift "Special Oil!" befindet sich im Bereich der Öleinfüllschraube.
Handelsname BMW Teilenummer Gebinde
Schaltgetriebeöl 81 22 9 407 305 20 Liter Kanister
Hinweis:
Zur Reduzierung von hohen Kaltschaltkräften bei tiefen Aussenemperaturen können während der kalten
Jahreszeit folgende Öle in das Getriebe eingefüllt werden:
- Einbereichs-HD-Motoröle auf Mineralbasis SAE40, SAE30, SAE20
- In Ländern mit besonders tiefen Aussentemperaturen können auch ATF-Öle (siehe Anlage 3.0) verwendet
werden.
Nachteil, bei höheren Temperaturen kann verstärktes Getrieberasseln bzw. Leerlaufklappern auftreten.
Achtung!
Keinesfalls gestattet ist eine Befüllung mit synthetischen Motorölen oder mit Mehrbereichs-Motorölen, da
diese Reibwertverminderer enthalten, die die Synchroneinrichtung in ihrer Funktion beeinträchtigen
können.
This post has been edited by MeHigh: Apr 19 2010, 12:00 PM
elvislorin
post Jun 13 2010, 09:51 PM
Cazan owner
bmw 5w30 1l - 30 lei
bmw 10w40 1l - 30 lei
bmw 5w40 1l - 30 lei
RSS Lo-Fi Version Time is now: 27th October 2025 - 10:05 PM
