> INCHIRIEZ SONORIZARE 750w, RCF
ionusunt
post May 10 2009, 04:37 PM
jah soldier
Car: E46 sedan 2.0d
Engine: M47TUD20 nusestieCP
boxe +bass : http://www.thomann.de/gb/rcf_art_710_a_bundle.htm
RCF ART 710-A, Active Full Range cabinet, 10" Neo-Woofer with a 2,5" voice coil, 1" Neo-Driver with a 1,7" voice coil, 750 Watt BiAmp Digital amplifier section, ABS Plastic Case with Aluminium Handles, Horn Dispersion 90°x60°, Frequency Range 50Hz - 20 KHz, SPL max. 129 dB, Dimensions 549x340x304mm, Weight 11,2 kg
RCF 905-AS Active Subwoofer - 15" Neo-Woofer with 3" voice coil, 1000W digital amplifier section, plywood birch cabinet, audio controller with active stereo frequency X-over and limiter, 45Hz-120Hz frequency response, 131dB maximum SPL. Dimensions: 600 x 445 x 600mm. Weight: 34kg
mixer : http://www.thomann.de/gb/yamaha_mg_124_c.htm
Yamaha MG 24C 12 channel mixer - 4 mono mic/line inputs (XLR/jack), 2 stereo mic/line inputs (jack), internal compressors on each mic channel, 2 stereo aux returns, 1 group out, 2 aux sends, 4 inserts, 3-band EQ, 18dB low cut filter, high end mic preamps, 48V phantom power. Dimensions: 346.2 x 86.1 x 436.6mm. Weight: 3kg
microfon: http://www.thomann.de/gb/akg_wms40_pro_flexx_vocal_set.htm
AKG WMS40 Pro FLEXX Vocal Set ISM - diversity wireless system with three switchable frequencies (863.100, 864.375 and 864.850MHz), 1x HT 40 Pro handheld transmitter with D880 capsule (works with one AA battery for up to 30 hours), SR 40 Pro FLEXX diversity receiver in metal housing, includes stand-adapter, batteries and power supply. Available in 3 different frequency groups.
pretul la astea e de 300euro pe seara(TRANSPORT INCLUS! )
PENTRU MEMBRII FORUMULUI PRETUL ESTE FOARTE NEGOCIABIL!!!!
ATENTIE!! E UN SISTEM PUTERNIC ! NU PT A FI FOLOSIT IN CASA! PT PARTY ACASA SAU CEVA.100% VINE POLITIA ! laugh.gif
IDEAL DACA AVETI NUNTI SAU DIVERSE EVENTURI DE GENUL SI NU DORITI SA DATI 30 DE MILIOANE PE UN SUNET DYNACORD MANA A15-A CU MEMBRANE LUATE DE LA CONNEX DE PE MAICA DOMNULUI wink.gif
This post has been edited by ionusunt: May 10 2009, 04:38 PM
Bob
Marley and the
Wailers
OO=[][]=OO
RSS Lo-Fi Version Time is now: 8th October 2025 - 08:26 AM
