9 Pages V  « < 5 6 7 8 9 >
> Uleiuri
BBo
post Jul 29 2007, 10:59 AM
Post #121
91% BMW corupt
Car: E30|E46
Engine: M20|M54
Pentru motoarele mai vechi, eu nu v-as sfatui sa faceti un flush.
QUOTE
Flushing oils
These are special compound oils that are very, very thin. They almost have the consistency of tap water when cold as well as hot. Typically they are 0W/20 oils. Don't ever drive with these oils in the engine - it won't last. (Caveat : some hybrid vehicles now require 0W20, so if you're a hybrid driver, check your owner's manual). Their purpose is for cleaning out all the gunk which builds up inside an engine. Note that Mobil1 0W40 is okay, because the '40' denotes that it's actually thick enough at temperature to work. 0W20 just doesn't get that viscous! To use them, drain your engine of all it's oil, but leave the old oil filter in place. Next fill it up with flushing oil and run it at a fast idle for about 20 minutes. Finally, drain all this off (and marvel at the crap that comes out with it), replace the oil filter, refill with a good synthetic oil and voila! Clean engine.
Of course, like most things nowadays, there's a condition attached when using flushing oils. In an old engine you really don't want to remove all the deposits. Some of these deposits help seal rings, lifters and even some of the flanges between the heads, covers, pan and the block, where the gaskets are thin. I have heard of engines with over 280,000km that worked fine, but when flushed it failed in a month because the blow-by past the scraper ring(now really clean)contaminated the oil and screwed the rod bearings.
Using Diesel oil for flushing
A question came up some time ago about using diesel-rated oils to flush out petrol engines. The idea was that because of the higher detergent levels in diesel engine oil, it might be a good cleaner / flusher for a non-diesel engine. Well most of the diesel oil specification oils can be used in old petrol engines for cleaning, but you want to use a low specification oil to ensure that you do not over clean your engine and lose compression for example. Generally speaking, an SAE 15W/40 diesel engine oil for about 500 miles might do the trick.
Mai multe informatii pe carbibles.com:
http://www.carbibles.com/engineoil_bible.html
Iulika0069
post Jul 29 2007, 05:35 PM
Post #122
Engine: S50 turbo 400+WHP
QUOTE (georgem)
Si la mine uleiul anterior a fost cam murdar, era cel de la fostul proprietar si din ce-a spus el era Castrol 5W40. Sunt curios daca uleiul pus de mine va fi mai curat sau la fel.
Nu neaparat murdar, cat urat mirositor (cel putin asa s-a exprimat mecanicul, mie nu mi s-a parut sa puta smile.gif mai mult decat de obicei)..
QUOTE (georgem)
Totusi, eu nu stiu daca merita sa-i faci engine flush. Uleiul curata componentele interne ale motorului de depuneri si de aceea e murdar. Eu n-as face.
Am tot citit despre asta, cred ca ma calmez cu engine flush si o sa traiesc in continuare cu mirosul smile.gif
QUOTE (georgem)
Tu vrei sa schimbi uleiul dupa 7k km sau mai astepti?
Mi-au zis mai multi ca in RO nu prea e bine sa il lasi mai mult de 7-8.000 de km, mai ales daca ii si mai dai din cand in cand spre redline tongue.gif
La tine e ok cred, ca i-ai facut cam toti prin afara
De-aia am si hotarat sa pun 10w40, ca e si mai ieftin, e si ce recomanda producatorul..
Cu banii "economisiti" biggrin.gif imi permit sa il skimb mai des; ma gandesc ca mai bine merg 5-7.000km cu 10w40 decat 8-10.000 cu 5w40 sau 12-15.000km cu 10w60 sau 0w30..
mertan
post Sep 1 2007, 06:05 PM
Post #123
Car: e30
Engine: m20 2.0 129CP
tare..... e treaba
butcky
post Oct 5 2007, 12:19 AM
Post #124
Car: e30 - 325ix din '89
Engine: 2.5 - 171 cp
Am gasit asta in Carrefour tongue.gif Poate va ajuta la ceva...
Azeea
post Nov 1 2007, 03:16 PM
Post #125
Car: 324 td e30 1989
Engine: M21 2.4TD 115CP
am facut aproape 7000 km cu Valvoline 15W40 si trebuie sa-l schimb. nu mi-a papat aproape deloc. ce recomanda colegii dieselisti, mai ales ca vine iarna?
324 td
Sorin
post Nov 1 2007, 04:05 PM
Post #126
Car: E46 Schwarz2
Engine: mic dar viguros
Poti sa mergi pe un 10w40 semisintetic cum se recomanda dar e posibil sa-l manance daca motorul nu a suferit vreo reparatie capitala .
La golf mergeam cu 10w40 in condititile in care motorul era cota 1 de reparatie si l-am vandut cu 60.000 de km facuti in 2 ani aproape .
To the aiiiiiiirport
Azeea
post Jan 9 2008, 10:25 AM
Post #127
QUOTE (Azeea @ Nov 1 2007, 03:16 PM) *
in cele din urma am ales valvoline maxlife 10w40, mai ales ca vine iarna.
324 td
Mouse
post Jan 15 2008, 05:44 PM
Post #128
Car: E85 Z4 Roadster
Engine: N46 2.0 150cp
eu am in motor castrol gtx 10-40semi...iar ex-u proprietar a bagat acelasi ulei de zeci de mii de km...dupa 5000-6000km inca e curat
ASISTENTA RUTIERA & TRANSPORT AUTO !!! 0721 157 976 !!!
liviubmwe30
post Mar 12 2008, 11:30 PM
Post #129
Car: bmw 318i touring e30
Engine: 1800cc
salut de curand am cumparat un urs 318i touring din 90 si motor de pisicutza din 96 si vreau sa schimb uleiul si cineva mi-a recomandat sa pun uleiul asta ULEI CASTROL HIGH MILEAGE 5W-30 PENTRU MOTOARE PESTE 120.000 KM pretul e ok dar din cate am citit eu pe forum reiese ca se poate sa-l cam "pape" astept pareri http://www.uleiuri.ro/product_info.php?pro...ef84b8354d8b0be
This post has been edited by liviubmwe30: Mar 12 2008, 11:31 PM
post Mar 13 2008, 12:46 PM
Post #130
W30 ar putea fi cam subtire pentru motorul tau. Mai bine un *W40. Sa vedem ce zic cei cu pisici si alte masini de dupa '90.
ionusunt
post Mar 13 2008, 01:02 PM
Post #131
jah soldier
Car: E46 sedan 2.0d
Engine: M47TUD20 nusestieCP
nu stiu de ce toata lumea face atatea experimente......10w40 pt oameni normali la cap si picioru drept ,10w60 la nebuni tongue.gif laugh.gif
Bob
Marley and the
Wailers
OO=[][]=OO
liviubmwe30
post Mar 13 2008, 02:28 PM
Post #132
Engine: 1800cc
asta e l-am luat sper sa am timp sa-l schimb si va spun cum merge si daca nu imi place cred ca revin la magnatec
Sorin
post Mar 13 2008, 03:49 PM
Post #133
Car: E46 Schwarz2
marca ca marca
dar cand cumperi uleiul trebuie sa fii atent la specificatiile de pe spatele lui
API CL CF A2 A3 B2 B3 B4
si daca intruneste recomandarile producatorului respectiv
liviubmwe30
post Mar 15 2008, 01:26 PM
Post #134
Engine: 1800cc
QUOTE (liviubmwe30 @ Mar 12 2008, 11:30 PM) *
salut am schimbat ulei am mers cam 200 km si vreau sa zic sa sunf foarte multumit sta cum trebuie la relanti nu mai tremura si cand ma gandesc ca cel pe care l-am schimbat era sintetic si nici nu avea 4000 de km si se comporta asa prost se auzea mototrul ca si cand mergea fara ulei
liviubmwe30
post Mar 26 2008, 05:49 PM
Post #135
Engine: 1800cc
salut revin cu inca o intrebare ce ulei de transmisie recomandatii???
post Mar 26 2008, 08:01 PM
Post #136
CITAT(liviubmwe30 @ Mar 26 2008, 05:49 PM) *
pt ce masina model/an de fabricatie?
de regula BMW recomanda ATF insa nu la toate modelele
liviubmwe30
post Mar 26 2008, 11:14 PM
Post #137
Engine: 1800cc
QUOTE (io`s @ Mar 26 2008, 08:01 PM) *
jakal
post Mar 26 2008, 11:54 PM
Post #138
55% BMW corupt
Engine: 2.4D 85CP
ce ulei de motor imi recomandati pt un urs 2.5 i, in conditiile in care stau numai cu talpa in radiator ,masina participa la curse,(legale binenteles),cerculete,burn....etc. intr-un cuvint masina forjata...multumesc..
E30..324D E30..325 I
post Mar 27 2008, 12:33 AM
Post #139
RS
sebaa
post May 4 2008, 04:43 PM
Post #140
27% BMW corupt
Engine: M10 1.8 105CP
Castrol EDGE SPORT 10w-60 e bun pentru M10 1,8 ?
pe site la ei pretind ca este mai bun de cat magnatec 10w-40 ..
acum am Valvoline 15w-40 (fostul proprietar a fost sfatuit sa puna din asta)
Ce sa cumpar ? EDGE 10w-60 ? Magnatec 10W-40 sau tot Valvoline 15w-40??
RSS Lo-Fi Version Time is now: 7th October 2025 - 09:24 PM
