May 4 2008, 09:37 PM
0% BMW corupt Group: Members Posts: 7 Joined: 4-May 08 Member No.: 1,619 Car: e39 Engine: 2.2 170cp |
Daca aveti nevoie de tester sunt dispus sa va ajut.Resetare airbag, oil sevice, diagnosticare abs,motor,pdc.... etc.
0727854471 Numai bine |
May 4 2008, 10:32 PM
spune si un pret
May 4 2008, 11:07 PM
50ron-10% pentru membrii forumului adica 45 ron |
May 4 2008, 11:13 PM
merci !
cu ce lucrezi? carsoft 6.5? ..si spune si o locatie. sau te deplasezi tu la domiciliu daca e nevoie? -------------------- "PUTEREA BATE CUPLU PT CA TOT TIMPUL VEI GASI O TREAPTA INFERIOARA UNDE SA O PUI"
May 4 2008, 11:25 PM
carsoft 6.5.06 Militari(apusului)Numai bine
May 6 2008, 09:51 PM
Schimbare de limba la comp de bord din germana in engleza. |
May 8 2008, 01:49 PM
activarea inchiderii usilor dupa ce depasesti 15 km/h
rectificare pret: 40 ron |
May 8 2008, 01:51 PM
![]() 55% BMW corupt ![]() ![]() ![]() Group: Members Posts: 613 Joined: 8-August 07 Member No.: 1,066 Car: E39 Engine: e12 |
Daca aveti nevoie de tester sunt dispus sa va ajut.Resetare airbag, oil sevice, diagnosticare abs,motor,pdc.... etc. 0727854471 Numai bine Asta cu "sunt dispus sa va ajut" a sunat a gratuit! -------------------- I can take you there faster....
May 9 2008, 09:39 AM
May 12 2008, 10:21 PM
Astept doritori de diagnoza.0727854471 Numai bine |
Lo-Fi Version | Time is now: 28th October 2025 - 05:20 AM |
