> Are cineva o placa de baza cu video on-board ATI x1200/x1250 sau GeForce 6100?
Shark
post Nov 28 2007, 12:10 AM
Car: E30 316i
Engine: M40B16 100CP
Deocamdata intrebarea nu prea are legatura cu BMW dar ... va avea in curand!
Daca are cineva o placa de-asta (sunt destul de noi daca nu ma insel, de obicei cu socket AM2), am nevoie de niste informatii despre functionarea ei.
Detalii, ceva mai incolo.
Multumesc!
This post has been edited by Shark: Nov 28 2007, 12:11 AM
mario.b
post Nov 28 2007, 11:28 AM
Engine: M20 2.0 93kW
Salutare man, eu lucrez la Depozitul de Calculatoare si am asa ceva pe stoc, uite cateva detalii despre ele
-- Placa de baza ASUS M2N-MX SE, nVIDIA nFORCE 430, AM2, 2xDual channel DDR2 800, VGA GeForce 6100, 1xPCIEXP16x, 6CH, LAN, SATAII, ATA133, 2000MTs, mATX - gr 36 luni - 201.47 lei -
Placa de baza GIGABYTE GA-MA69VM-S2, AMD 690V, AM2, 4xDual channel DDR2 800, 1xPCIEXP16x, 1xPCIEXP4x, VGA RADEON X1200, 8CH, LAN, SATAII, ATA, 2000MTs, mATX - gr 36 luni - 199.44 lei -
Placa de baza ASUS M2N-MX SE PLUS, nFORCE430, AM2/ AM2+, 2xDual channel DDR2 1066, VGA NVIDIA GeFORCE 6100, 1xPCIEXP16x, 6CH, LAN, SATAII, ATA133, 2000MTs, AM2+ CPU Ready, mATX - gr 36 luni -213.46 lei-
Placa de baza ASUS M2N-MX, nVIDIA nFORCE 430, AM2, 4xDual channel DDR2 800, VGA GeForce 6100, 1xPCIEXP16x, 1xPCIEXP1x, 6CH, Gigabit LAN, SATAII, ATA133, 2000MTs, mATX - gr 36 luni -215.87 lei -
Placa de baza ASUS M2A-MX, AMD 690V, AM2/ AM2+, 2xDual channel DDR2 800, VGA ATI RADEON X1200, 1xPCIEXP16x, 1xPCIEXP1x, 6CH, Gigabit LAN, SATAII, ATA133, 2000MTs, AM2+ CPU Ready, mATX - gr 36 luni -216.39 lei-
Placa de baza ASUS M2A-VM, AMD 690G, AM2, 4xDual channel DDR2 800, VGA RADEON X1250, DVI, 1xPCIEXP16x, 1xPCIEXP1x, 6CH, Gigabit LAN, SATAII, ATA133, 2000MTs, mATX - gr 36 luni - 219.67 lei
Ideea este ca nu gasesti sau cel putin nu avem noi in stoc variante cu echipari video on board (6100 . 1200 . 1250) care sa fie si pe LGA775, diferentele intre ele sant de northbrige, fie este mai nou fie este mai vechi si modificat sa poata sa mearga si pe socket AM2, cele mai vechi sant nForce 4 care sant un pic modicate, in sensul care li s-au adaugat instructiuni noi si controlerul de memorie a fost modicat pentru DDR2, si de aici s-au facut nForce 430 -urile, care au fost imprumutate de pe platforma 939 imbunatatite si vandute la un pret inferior cipseturilor nForce 5 sau 6. Per total cat dai atata face, daca nu ai nevoie sa te joci sau sa rulezi aplicatii 3D consumatoare de resurse sau ai un buget limitat te poti regasi foarte lejer in aceste placi, daca vrei performanta mai multa ..... . Sper sa iti fie de folos informatiile. Bafta
This post has been edited by mario.b: Nov 28 2007, 11:28 AM
Shark
post Nov 28 2007, 12:25 PM
Car: E30 316i
Multumesc Mario, foarte utile informatiile.
Daca tot spui ca lucrezi la Depozitul de Calculatoare, atunci mai am cateva intrebari suplimentare! Opinia ta sigur o sa-mi fie foarte folositoare! smile.gif
Prin urmare, sa iti zic intai de ce am nevoie. Imi trebuie o placa de baza mica (adica format mATX), la care nu conteaza prea mult dotarile, in afara de 2 kestii. Vreau sa fie cu AMD (ma gandesc sa un Athlon 64 single core, daca mai gasesc, sau X2) si neaparat cu placa video on board mai moderna.
Placa asta va fi baza unui sistem multimedia stand-alone. Sistemul nu va fi prea solicitat: mp3 player, video player divx, mai rar DVD, niciodata jocuri sau HD. Prin urmare trebuie sa produca foarte putin caldura. Asa ca m-am gandit sa pun un Athlon 64 4000 de ex, caruia sa ii fac underclocking pe la 800-900Mhz, cu un vcore de 0,8-0,9v, vad eu, cel mai mic voltaj cu care merge stabil. In felul asta nici nu o sa faca prea mult zgomot si nici caldura.
Mai mult, locul alocat lui este foarte plat, abia incape un cooler custom de CPU, nici vorda de cartela video PCIe. Prin urmare placa video on board este foarte importanta. Nu ma intereseaza la ea sa aiba acceleratii 3d sau alte nazbatii. Ea va functona permanent la rezolutie 800x480, pe un LCD cu frecventa fixa. LCDul are pixel clock de 16 MHz, ceea ce se traduce intr-un refresh vertical de vreo 37Hz (nu mai stiu exact, am datele pe undeva). Iti dai seama ca acest mod video custom nu se poate obtine decat cu PowerStrip.
Prin urmare, singura si cea mai importanta caracteristica pt placa video on board este ca trebuie sa suporte PowerStrip. Am incercat cu PowerStrip pe un laptop cu ATI RADEON x300 si merge perfect, la fel pe un ATI Radeon 1950 (vechi).
Nu am lucrat insa niciodata nici cu GeForce 6100 on board si nici cu ATI x1250. Asa ca iti dai seama ca nu imi pot cumpara nici o placa de baza din asta pana nu ma lamuresc daca va colabora cu PowerStrip. Pe forumul lor zice ca sunt suportate, dar parca nu e suficient. Pana nu ma lamuresc exact cu PowerStrip-ul ca intra in Custom Resolutions si Advanced Timing cu o astfel de placa, nu pot face nimic.
Aici am mare nevoie de ajutor. Please help!
Eventual, daca ai un alt sistem de test care functioneaza pe undeva, sa te uiti un pic la el, cu placa video on board mai veche si socket 775, 939 sau oricare, nu ma deranjeaza, doar video sa fie compatibil cu PowerStrip-ul asta! Ti-am zis: CPU underclocat, sa consume cat mai putin si sa faca putina caldura si placa video compatibila cu PowerStrip. Asta-i tot!
mario.b
post Nov 29 2007, 12:31 AM
Man ai 2 alternative, una din ele este sa vii in magazinul meu din Rahova si testam sa vedem daca se poate ce vrei tu sau astepti pana pot testa asa ceva asta in cazul in care nu gasesc baieti care au facut asa ceva pe la noi in firma pe astfel de placi.
Shark
post Nov 29 2007, 12:48 AM
Car: E30 316i
Mmmm.... cred ca e destul de greu sa ajung pe la tine prin Rahova, avand in vedere ca eu sunt din Iasi. smile.gif Prin urmare, ma rezum la a doua varianta. Te rog, daca ai ocazia (tu sau amicii tai) sa testezi daca vreo placa din asta merge cu PowerStrip. Daca ai nevoie, pot sa iti trimit eu kitul de instalare, ca sa nu il mai descarci de pe net.
Chiar m-ar ajuta mult de tot un test, ca nu prea am cum sa imi cumpar o placa si apoi sa vad ca nu merge ....
Multumesc mult.
George77
post Nov 29 2007, 02:59 AM
Car: e30 318is
Engine: m42 +12psi of boost
Ai putea sa cauti sa vezi daca gasesti un ACER ASPIRE L100 ,eu asa ceva mi-am luat pt car pc.acum caut display de 10 inch cu vga.
Shark
post Nov 29 2007, 11:28 AM
Car: E30 316i
Mda, m-am gandit si la asta ... Am gasit un Dell Optiplex mic, mic, mic dar ... nu stiu de ce, parca nu ma prea atrage .... Plus ca oricum trebuie sa renunt la sursa lui si sa pun una auto. Ma gandeam sa pornesc din start cu o placa noua.
George77
post Nov 30 2007, 03:16 AM
Car: e30 318is
Pai dell ul ala este mare rau,cauta s avezi cate aste Acerul despre care ti-am spus,si in plus poti sa mergi cu un invertor ,eu am unul de 400W pot alimenta si un tv cu el.Cauta sa vezi de curiozitate cat de mic este acerul,intra in torpedo fara probleme,poate chiar si sub scaun depunde de ce scaune ai.
Shark
post Nov 30 2007, 04:42 PM
Car: E30 316i
Nu-i asa mare Dell-ul. Este seria SX (SX260). Uite-l aici:
Din pacate chipsetul e bazat pe Intel 845G si asta nu stie custom resolutions.
Acer Inspire L100 ar fi insa foarte bun, mai ales ca vad ca are GeForce 6150. Ms pt pont! lnr (1).gif Informatiile de pe net insa sunt contradictorii. Nu pot garanta ca merge ce vreau eu pina nu il testez. Din pacate nu am vazut nicaieri prin Iasi vreunul. Tu zici ca ai deja unul din asta? Nu poti face pe el un test, te rog frumos?
Iar kestia cu invertorul nu imi place. Ala doar imi asigura curent de 220 din 12v, atat! Deci consumuri de curent mari (are si invertorul un randament, care insa nu e prea grozav) si in plus nu are nici o legatura cu instalatia electrica a masinii.
Eu vreau asa ceva. Este, cred, cea mai tare sursa auto. Are si pornire/oprire cu delay (prin microcontroller), este controlata de "ignition signal" si este absolut microscopica!
Dar oricum, sa imi iau intai MB+CPU+RAM si apoi comand si asta.
Uita-te si tu pe http://www.cartft.com, s-ar putea sa iti gasesti un LCD dupa dorinta. Preturile nu sunt chiar cele mai mici dar au avantajul ca sunt in Germania si iti ajunge totul rapid si fara costuri suplimentare. AU si partener in Romania, www.optix.ro, dar sunt cam slabuti.
Prin urmare, mai caut Acer din ala si daca nu, cred ca fac o incercare cu ASUS M2A.
This post has been edited by Shark: Nov 30 2007, 04:43 PM
RSS Lo-Fi Version Time is now: 8th October 2025 - 12:54 PM
