Sistemul de injectie pentru motorul M30 de 2800 cmc, L-Jetronic fara sonda Lambda, este monopunct sau multipunct ? Stie cineva ?
LE: sorry, am postat de 2 ori. Rog admin-ul sa stearga acest post. This post has been edited by nmg: Jan 27 2007, 07:01 PM -------------------- Life is too short to drive anything less than a BMW ...
multipunct, normal, doar ai cate un injector pt fiecare cilindru (exceptand injectorul de pornire)
Faptul ca exista cate un injector pe fiecare cilindru nu inseamna ca sistemul de injectie este multipunct. Din cate imi amintesc eu, monopunct inseamna faptul ca in timpul cursei de admisie, injectorul se deschide o singura data. Multipunct, pulverizeaza de mai multe ori. -------------------- Life is too short to drive anything less than a BMW ...
Nope, are dreptate io's multipunct e un injector pe cilindru, monopunct e un singur injector pe galeria de admisie, ceva mai primitiv, deci in loc de carburator ai un singur injector.
PS: Ce zici tu de pulverizare multipla e common rail.. atat stiu despre injectie diesel ![]() This post has been edited by xox: Jan 27 2007, 08:32 PM -------------------- Ex: M10B18(Pierburg)/18(L-Jetronic)/18(Pierburg)/M43TUB19/M20B20
Faptul ca exista cate un injector pe fiecare cilindru nu inseamna ca sistemul de injectie este multipunct. Din cate imi amintesc eu, monopunct inseamna faptul ca in timpul cursei de admisie, injectorul se deschide o singura data. Multipunct, pulverizeaza de mai multe ori. io`s right! de unde ai scos-o ' Multipunct, pulverizeaza de mai multe ori ' ??? L Jetronic (1974 - ca 1985) - analog electronic fuel injection. Uses a flapper-type AFM, or Air Flow Meter, to measure airflow into engine. It had a much simpler and more reliable ECU than D-Jetronic, due to use of custom-designed integrated circuits. This type of air flow meter is called LMM, LuftMassenMesser, in all Bosch documentation. It was used heavily in 1980's-era European cars [1]. Similar systems have been built under license by Lucas, Hitachi Automotive Products, Nippondenso, and other companies; though their key components look similar to L-Jetronic parts, those systems should not be called L-Jetronic and parts are usually not compatible. The meaning of the letter L is disputed, either it stands just for Luft - air, or it might be just because it is the letter after K in the alphabet, and L-Jetronic came immediately after K-Jetronic. This post has been edited by iulian325: Jan 27 2007, 08:40 PM |
Ok, poate m-am inselat. Nu stiti ca memoria e de genul feminin ? Te lasa cand ti-e lumea mai draga ? ![]() -------------------- Life is too short to drive anything less than a BMW ...
pana si pe masina mea este multipunct.doar nu faceau regres:PP
Hmmm, din cate stiu L-Jetronic e monopunct. Adica arunca benzina in acelasi moment prin toate injectoarele, nu in functie de pozitia pistonului. De la motronic in sus e multipunct.
bai mecanicule . i a mai citeste d_jetronic. mpci
M-am lamurit. http://rb-k.bosch.de/resources/literatur/l...roben/u214e.pdf Nu stiu pe unde auzisem ca daca ai injectoare pe fiecare cilindru nu inseamna ca-i multipunct, si ca multipunct inseamna de fapt ca fiecarui injector i se comanda separat momentul deschiderii. Tot asa am auzit ca la L-jetronic injectoarele se deschid simultan, deci practic ECU-ul da o singura comanda de deschidere, comanda transmisa tururor injectoarelor. Chestia cu pulverizarea multipla stiu ca merge doar la injectie directa (deci la common rail si poate la noile motoare pe benzina de la VAG). -------------------- Inline 6 in a 5-er 4 ever
mdea, cred ca se facea confuzie intre injectia mecanica (folosita de mercedes si VW in anii "80) si injectia electronica, la injectia mecanica injectoarele pulverizeaza toate odata, la injectia electronica injectoarele pulverizeaza numai atunci cand e nevoie (cu toate ca am vazut pe VW si injectie electronica care pulverizeaza toate injectoarele odata
![]() si da , injectia monopunct este un fel de carburator mai evoluat, comandat de un computer care are un singur injector ce pulverizeaza benzina ![]() ![]() edit: si ca sa dau exemplu de motor cu injectie monopunct : DACIA BERLINA/NOVA GTI cu motor "pa folie" ![]() This post has been edited by io`s: Jan 28 2007, 04:36 PM -------------------- "PUTEREA BATE CUPLU PT CA TOT TIMPUL VEI GASI O TREAPTA INFERIOARA UNDE SA O PUI"
Tot nu-s lamurit complet. Ma uit pe wikipedia la: http://en.wikipedia.org/wiki/Jetronic#K_Jetronic
si inteleg ca: 1. injectia mecanica nu doar ca arunca benzina simultan benzina prin toate injectoarele, dar arunca tot timpul. Probabil parametrul regulat de injectie e debitul din injector (presiune variabila), nu perioada de deschidere, ca la L-Jetronic. QUOTE K Jetronic 2. in afara de binecunoscuta injectie monopunct, cu un singur injector, folosita pe foarte multe modele in anii '90 si pe berlina pana de curand, mai exista injectia singlepoint. Probabil asta e tipul despre care spuneam ca deschide injectoarele simultan. Dar nu scrie care-s alea singlepoint...(1974 - ca 1988)- mechanical fuel injection. K stands for Kontinuierlich, i. e. continuous. Different from all other systems in that the fuel flows continuously from all injectors QUOTE Mono-Jetronic is different from all other known single-point systems ........ Concluzia e ca L-Jetronic e multipunct, conform likului din postul anterior (care e un pdf de la Bosch). Intrebarea e care sunt injectiile singlepoint? Si inca ceva: care sunt motoarele cu LE-Jetronic la BMW? Presupun ca BMW a folosit doar LE1, pentru ca LE2 nu mai are injector de pornire si cred ca toate BMW-urile cu LE-Jetronic au injector de pornire. QUOTE Three variants of LE-Jetronic exist: LE1, the initial one. LE2, from about 1984 on, it has cold start functionality integrated in the ECU and does not need the cold start injector and thermo time switch which was used by older systems. LE3, from about 1989 on.......
0% BMW corupt Group: Members Posts: 59 Joined: 7-January 07 Member No.: 509 Car: e 28 Engine: m30 2.8 ![]() |
Dupa cunostintele mele si mai pe romaneste: Injectia de benzina dupa locul in care se produce si numarul de cilindrii pe care un injector ii alimenteaza,se imparte in doua: MONOPUNCT atunci cand un ijector alimenteaza toti cilindri sau grupuri de cate 3 in cazul motoarelor cu mai mult de 4 cilindri prin intermediul unei galerii de admisie cu scopul de a se obtine distante egale de la punctul de injectie si cilindrii,ETC si MULTIPUNCT cand fiecare cilindru este alimentat de cate un injector,asa numita ijectie in poarta supapei.Acum dupa modul in care sunt comandate injectoarele INJECTIA se imparte iarasi in doua:CONTINUA si INTERMITENTA.Injectia mecanica cu distribuitor de presiune,cu taler cea de la vw golf de care aminteati voi sus este de inalta presiune si considerata continua.Cealalta intermitenta este mai des folosita,si este vorba de injectia electronica guvernata de un bloc electronic( calculator).Denumirea de intermitenta i se atribuie tocmai dupa modul cum sunt comandate injectoarele,adica o data la fiecare doua cicluri motor se deschid simultan toate injectoarele. Cat se deschid asta e treaba blocului electronic,care pe baza informatiilor primite de la diferiti senzori,a pozitiei clapetei de acceleratie si asondei lambda comanda un timp optim de deschidere.Nu stiu cat reusesc dar cu cele scrise mai sus incerc sa aduc putina lumina asupra clasificarii injectiilor tocmai sa se evite cazurile cand se poate crede ca o ijectie multipunct poate fi monopunct.Personal cred ca injectia SINGLE POINT e acelasi lucru cu MONOPUNCT. Deci in concluzie injectia monopunct este intermitenta
Si inca ceva: care sunt motoarele cu LE-Jetronic la BMW? de pe seria 3 e21 323i, adika motorul M20 6 cil. numai ca are injectie mecanica
injectia mecanica de pe e21 323i se numeste k-jetronic
injectia mecanica de pe e21 323i se numeste k-jetronic da? scuze atunci!![]() -------------------- "PUTEREA BATE CUPLU PT CA TOT TIMPUL VEI GASI O TREAPTA INFERIOARA UNDE SA O PUI"
Tot nu-s lamurit complet. Ma uit pe wikipedia la: http://en.wikipedia.org/wiki/Jetronic#K_Jetronic si inteleg ca: 1. injectia mecanica nu doar ca arunca benzina simultan benzina prin toate injectoarele, dar arunca tot timpul. Probabil parametrul regulat de injectie e debitul din injector (presiune variabila), nu perioada de deschidere, ca la L-Jetronic. Exact, injectoarele pulverizeaza continuu benzina si cantitatea pulverizata e in functie de presiune. Presiunea e reglata de talerul de pe admisia de aer. K-Jetronic am eu pe Audi 80. -------------------- |
Ok, m-am lamurit. Nu stiu de unde am scos chestia cu pulverizarea multipla dar o sa mai sap ... ![]() Inca o intrebare: de unde (si daca) se poate regla turatia de mers in gol pentru acest tip de motor ( M30, 2,8, L-Jetronic) ? -------------------- Life is too short to drive anything less than a BMW ...
adika ralantiul?
da se poate, exista un surub undeva sub burduful de admisie care intra in corpul clapetei de acceleratie (nu stiu daca ai inteles dar am sa caut o poza sa vezi) edit: am gasit poza undeva cu aproximatie unde e varful sagetii This post has been edited by io`s: Jan 30 2007, 11:55 AM -------------------- "PUTEREA BATE CUPLU PT CA TOT TIMPUL VEI GASI O TREAPTA INFERIOARA UNDE SA O PUI"
Ok, trebuie sa mai caut.
![]() Poza in schimb nu se prea potriveste cu motorul meu. La mine sunt o gramada de matze pe sub burduful ala si probabil din cauza asta nu l-am vazut. -------------------- Life is too short to drive anything less than a BMW ...
Lo-Fi Version | Time is now: 17th September 2025 - 08:42 PM |
