Dec 8 2006, 01:12 PM
![]() 0% BMW corupt Group: Members Posts: 66 Joined: 1-November 05 Member No.: 79 Car: e36 Engine: S50 |
Mai are garantie pana pe 19.11.2006
Functioneaza perfect,nu a fost umblat in el,nu a avut nici o problema L-am cumparat de nou.Am la el toate actele,manualele,firele,mufele,clemele... Mai jos poze reale cu fata playerului P.S.: Are FOARTE MULTE setari Pret: 530 ron Tel: 0722 255 559 Specificatii: MP3 / WMA / WAV CD playback MOSFET 50 W x 4 amplifier EEQ+ equaliser with LPF & HPF EQ-EX IP-Bus (MCD, TV, 2 EXT) BMX (bitmetric equaliser) 2 pre-outs Multi-colour LED display Features - General Multi-CD Control - Yes CD Text - Yes Source TV Control - Yes DAB Tuner Control - EXT Source DVD Control - EXT External unit control via IP-Bus - 2 AUX-In (with optional CD-RB20) - Yes Remote control - Optional Hard-wired remote input - Yes ISO Connector - Yes Display illumination - MULTI Rotary volume - Pop-out Front Panel - Flap type (mechanical) Removable Front Panel - Yes Cellular telephone auto muting - Yes Flexible angle installation - 0-60° Features - Tuner Adaptive RDS (PI, PS, AF, TP/TA) - Yes PTY (Search and Alarm) - Yes Radio Text - Yes ARC FM - D4Q BSA (Best TP Station Auto Search) - Yes High speed PLL Synthesiser tuner - Yes PNS (Pulse Noise Suppressor) - Yes No. of Presets - 24 BSM (Best Stations Memory) - Yes Features - CD player Oversampling digital filter - 8x D/A Converter - 1-Bit Fast forward/reverse - Yes/Yes Track Search/Scan/Repeat - Yes/Yes/Yes Track/Manual search - Yes/Yes Random Play - Yes Last position memory - Yes Disc Title Memory - Yes CD Text - Yes CD-R Playback - Yes MP3 - Yes Windows Media™ Audio - Yes CD-RW Playback - Yes WAV - Yes Features - Audio / Amplifier Max. output power (watts) - MOSFET 4 x 50 Watt DIN output power (DIN45324, +B=14.4 V) - 4 x 27 Watt Max. preout voltage (V / Ohms) - 2,2 HPF - Yes LPF - Yes EEQ Plus - Yes 5-mode preset equaliser - Yes Custom preset equaliser - Yes 3-band parametric equaliser - Yes Source Equalisation Memory - Yes Selectable Loudness - Yes EQ-EX - Yes SFEQ (Sound Focus Equaliser) - Yes Direct Sub Drive - Yes Level Indicator - Yes Loudness - Yes Source level adjuster - Yes Fader - Yes RCA Preout - 2 (F + S/W or Non FAD) Specifications - FM Frequency range - 87,5-108 MHz Usable sensitivity (75 ohms) - 8 (0,7) dBf/µV S/N ratio - 75 dB Frequency response - 30-15.000 Hz Stereo separation - 45 dB Specifications - MW Frequency range - 531-1.602 kHz Usable sensitivity - 18 µV Specifications - LW Frequency range - 153-281 kHz Usable sensitivity - 30 µV Specifications - CD Frequency response - 5-20.000 Hz S/N ratio - 94 dB/1 kHz Dynamic range - 92 dB/1 kHz Specifications - General Chassis size (W x H x D) - 178 x 50 x 157 mm -------------------- ![]() |
Dec 8 2006, 01:47 PM
si cum suntem in decembrie,garantia a expirat acum o luna
Dec 8 2006, 07:25 PM
a citit cineva toata lista de specificatii? eu doar m-am uitat la tipa din avatar |
Dec 10 2006, 05:25 AM
eu unu sigur n-am citit-o,am dat copy paste de la ei de pe site..
Dec 23 2006, 09:30 PM
up
Dec 23 2006, 11:24 PM
tot femeia din avatar... aia ce caracteristici are? |
Dec 27 2006, 01:32 PM
minora
Lo-Fi Version | Time is now: 28th October 2025 - 06:15 AM |
