> Bara de rigidizare
Tytus
post May 11 2006, 11:22 AM
Z4 Fan
Car: exE46 325Ti
Engine: exM54TU 2.5 192cp
Ma bate gandul sa imi pun bara de rigidizare intre capetele amortizorelor fata. Are cineva? E diferenta? Merita? biggrin.gif
http://m3.madrussian.net/diy_oem_strutbar.shtml
exE46 325Ti, Silver metallic.
Suzuki GSR600 B-King K7,Blue ; Kawasaki ZZR1400A 2008,Metallic Midnight Sapphire Blue ; Sachs MadAss125 2009,Matte Black.
Motocicleta mea Suzuki GSR600
Motocicleta mea Kawasaki ZZR1400
Motoreta mea Sachs MadAss125
Acoperisul meu de iarna: Green Cozy Tico
Rotti
post May 11 2006, 12:29 PM
Engine: S54 3.2 343 cp
nu ajuta decat in cazul in care faci drifturi, unde apar forte laterale
post May 11 2006, 12:54 PM
ce ti-am zis? :finger:
CAT
post May 11 2006, 06:04 PM
64% BMW corupt
QUOTE
depinde ce masina ai
post May 11 2006, 06:26 PM
325 e46 compact...
post Jun 3 2006, 09:36 PM
mi se pare mie, sau mai folositoare e una intre amortizoarele spate? mai ales la o masina cu tractiune spate..
masina oricum se ridica mai rau de rotile din spate intr-un viraj
n3o
post Jun 3 2006, 11:54 PM
CSL fan
Car: e39 530da touring
Engine: 3.0D
pai ar trebui sa se simta prezenta si pe fata la viraje ma gandesc k ultimile M-uri nu degeaba au strut bar-urile montate din fabrik
CAT
post Jun 4 2006, 12:24 PM
64% BMW corupt
strut bar = brace consisting of a bar or rod used to resist longitudinal compression
la motoarele mari ajuta - tine "oalele" sa nu fuga fiecare in alta directie. am vazut diferenta intre e30 325 cu si unul fara. cel fara avea rotile din fata / .
asta ar fi o explicatie mai din popor - pt pareri mai documentate :
A strut bar or strut brace is a mostly aftermarket car suspension accessory used in conjunction with MacPherson struts on monocoque or unibody chassis to provide extra strength between the strut towers.
With a MacPherson strut suspension system where the spring and shock absorber are combined in the one suspension unit, the entire vertical suspension load is transmitted to the top of the vehicle's strut tower, unlike a double wishbone suspension where the spring and shock absorber may share the load separately. In general terms, a strut tower in a monocoque chassis is a reinforced portion of the inner wheel well and is not necessarily directly connected to the main chassis rails. For this reason there is inherent flex within the strut towers relative to the chassis rails.
A strut bar is designed to reduce this strut tower flex by tying two parallel strut towers together. This transmits the load of each strut tower during cornering via tension and compression of the strut bar which shares the load between both towers and reduces chassis flex.
A direct result of this is improved chassis rigidity (similar to that gained from a lower tie bar); hence, the understeer is reduced, tire wear improved and metal fatigue is greatly reduced in the strut tower area. Following the aftermarket's lead, some manufacturers have started fitting strut bars to performance models, including the NISSAN Skyline R34 and the HOLDEN VY II Commodore, as standard equipment.
Iulika0069
post Jun 4 2006, 02:26 PM
Engine: S50 turbo 400+WHP
Pt E36/E46 merita unul de carbon biggrin.gif
http://www.umnitza.com/product_info.php?cP...8053505b6b3d342
n3o
post Jun 4 2006, 04:32 PM
CSL fan
Engine: 3.0D
merita ... merita .. dar la pretul ala isi pune si pe spate
RSS Lo-Fi Version Time is now: 7th October 2025 - 04:17 AM
