> Vand statie MAC AUDIO MP4000
evildeath
post Nov 4 2011, 07:43 PM
Car: E23
Engine: M30 3.5
Max. Ausgangsleistung (Sinus Burst 2:8, 1 kHz) an 4 Ohm, 14,4 V 4 x 180/ 2 x 500 Watt
Max. power output (sine burst 2:8, 1 kHz) into 4 ohms , 14.4V 4 x 180/2 x 500 watts
Max. Ausgangsleistung (Sinus Burst 2:8, 1 kHz) an 2 Ohm, 14,4 V 4 x 250 Watt
Max. power output (sine burst 2:8, 1 kHz) into 2 ohms, 14.4 V 4 x 250 watts
Nennleistung (DIN 45 324) an 4 Ohm, 14,4 V 4 x 60/ 2 x 160 Watt
RMS power output (DIN 45 324) into 4 ohms, 14.4 V 4 x 60/2 x 160 watts
Nennleistung (DIN 45 324) an 2 Ohm, 14,4 V 4 x 80 Watt
RMS power output (DIN 45 324) into 2 ohms, 14.4V 4 x 80 watts
Frequenzgang 5 – 50 kHz (-3 dB)
Frequency response 5 – 50 kHz (-3 dB)
Klirrfaktor 100 dB
Signal-to-noise ratio (A-weighted) > 100 dB
Eingangsempfindlichkeit 0,4 – 4 V
Input sensitivity 0,4 – 4 V
Eingangsimpedanz 20 kOhm
Input impedance 20 kOhms
Stromversorgung 12 V minus an Masse
Power supply 12 V negative ground
Abmessungen (B x H x T) 319 x 59 x 226 mm
Dimensions (W x H x D) 319 x 59 x 226 mm
Gewicht 2,65 kg
Weight 2.65 kg
Functioneaza perfect
PRET: 350 RON
0724014184
This post has been edited by evildeath: Nov 4 2011, 07:43 PM
RSS Lo-Fi Version Time is now: 28th October 2025 - 02:02 PM
