Uleiuri |
Uleiuri |
Dec 24 2005, 11:18 PM
Nu stiu daca mai e un topic deschis pe tema asta, daca exista rog un moderator sa-mi mute postul.
Zo, trebuie sa schimb uleiul la ursulica: ce sa pun? - 10W40 BMW OEM - 10W40 Castrol (de care?) - 5W40 Castrol (de care?) Sau ce alte sugestii aveti? Multumesc! -------------------- 16 valves, 24 hours a day, 1bar boost. A vulgar display of power. Making boost since 30-06-2008. |
Dec 24 2005, 11:48 PM
82% BMW corupt Group: Members Posts: 821 Joined: 18-October 05 From: Bucuresti Member No.: 18 Car: E21 Engine: M20 2.3 143CP |
RS :cool:
-------------------- BMW E21 323i 2.3l K-Jetronic, 17" Alpina
Dec 25 2005, 08:43 AM
36% BMW corupt Group: Insiders Posts: 374 Joined: 19-October 05 From: Bucuresti Member No.: 32 |
Floriol .. Castrol RS 5w40 sau 10w60 -------------------- '99 E36 Compact - M50B20 max 95kw ...
Dec 25 2005, 08:51 AM
100% BMW corupt Group: Members Posts: 1,341 Joined: 24-November 05 From: IASHIngton- bacau Member No.: 103 Car: e30 Engine: m20 2.0 129CP |
castrol sunt cele mai bune. alea cu magnezium parca gt3 parca. nu imi aduc aminte. si un dura lube de la mama lui.
Dec 25 2005, 09:58 AM
si de ce sa dai dublu pe unu castrol cand poti sa iei din ala de la Bmw, care tot castrol am inteles ca e.. si totusi.. e ulei Bmw
Dec 25 2005, 12:09 PM
un 10w-40 de la castrol este f bun,nu are sens sa iei RS numai daca stai cu el prin forje ,in rest nu se diferentiaza decat la temperaturi mai inalte unde cecelalte nu isi mai fac treaba.La unnele masini am observat ca rs -ul face depuneri ,la Bmw nu am vazut -------------------- UPGRADES SO FAR:12psi of boost,Fidanza 13lbs flywheel, M3 BULLY stage 3 clutch(240mm), getrag260 transmission,Coils over plugs (COP),Stock engine
Dec 25 2005, 12:16 PM
100% BMW corupt Group: Insiders Posts: 1,723 Joined: 19-October 05 From: Bucuresti Member No.: 29 Car: BMW E46 318I 2002 Engine: N42 2.0 143CP |
Castrol 10w-40...altceva nu...
Dec 25 2005, 09:25 PM
RS-ul 10W60 e foarte bun, n-am ce sa-i reprosez, dar pentru mine nu e bun iarna. Vara e foarte ok, dar iarna nu pentru ca e prea subtire. :|
Ok, iau 10W40 Castrol maine. :nod: -------------------- 16 valves, 24 hours a day, 1bar boost. A vulgar display of power. Making boost since 30-06-2008. |
Dec 25 2005, 09:40 PM
82% BMW corupt Group: Members Posts: 850 Joined: 19-October 05 From: Bucuresti Member No.: 31 Car: E92 325i Engine: 218CP |
Castrol TXT 5W40 asta folosesc eu
Mar 9 2006, 11:55 PM
pentru noi amaratzii cu m20 ce ulei sa punem? ca eu am benzina in ulei. si trebe sa fac schimbul. neaparat. mai trebuie sai verific injectoarele si rampa si pompa de benzina. si sa pun si filtrul de benzina pe care il am in portbagaj. sa le iau pe fiecare in parte a le fac. ce ulei e mai bun? cat costa ala de bmw? |
Mar 10 2006, 09:30 AM
QUOTE (316i) RS-ul 10W60 e foarte bun, n-am ce sa-i reprosez, dar pentru mine nu e bun iarna. Vara e foarte ok, dar iarna nu pentru ca e prea subtire. :|
eu stiam tocmai invers :eek: -------------------- |
Mar 10 2006, 10:34 AM
nu merg toti cilindrii. si asta e de la bobina de la delcou. lasa ca o fac eu. nui pb.
Mar 10 2006, 11:20 AM
CristiC Group: Insiders Posts: 1,138 Joined: 19-October 05 From: Ploiesti Member No.: 26 Car: E87 Engine: 116i 115cp 2007 |
eu folosesc elf sporti txi 15W40 si sunt multumit de el :nod:
-------------------- ex E30; ex E46; now E87
Mar 11 2006, 10:23 AM
45% BMW corupt Group: Members Posts: 483 Joined: 19-October 05 From: Bucuresti Member No.: 30 Car: 324 td e30 1989 Engine: M21 2.4TD 115CP |
tb sa fac schimbul de ulei. a pus cineva mol carrier la motor turbo diesel? e destul de bun ca pret (10ron/l) dar nu stiu cat de bun este calitativ.... -------------------- 324 td
Mar 11 2006, 10:44 AM
45% BMW corupt Group: Members Posts: 498 Joined: 23-October 05 From: Bucharest Member No.: 51 Car: E30 Engine: S50 turbo 400+WHP |
Iarna asta am folosit Mobil 5W40 din metro/carrefour/cora etc - vreo 210RON/bidon 4l
Prin aprilie-mai o sa il skimb (~8.000km) cu Castrol TWS 10w60 dela BMW - "succesorul" lui RS, mai bun decāt el din cate am inteles si mai putin gros, chiar daca are aceeasi clasa de vāscozitate Io nu as merge iarna cu RS, dimineata probabil ca e un fel de marmelada in loc de ulei.. -------------------- E30 S50 turbo :D
trafficlight.bitdefender.com |
Mar 11 2006, 11:22 AM
Exact. :nod:
Mar 11 2006, 01:00 PM
de unde iau si eu ulei dinala de bmw? au astia la ausburg iasi? si cate kg incap intr-un m20 2.000 cmc? vreo 5?
Mar 11 2006, 02:16 PM
TWS nu cred ca il gasesti decat la BMW in Otopeni (nu stiu de Filaret) La mine intra 6.5l :unibrow:, M20B20 se pare ca ia 4.3l.. -------------------- E30 S50 turbo :D
Mar 11 2006, 03:20 PM
Cel mai indicat este sa pui valoarea fluiditatii si cea a vascozitatii recomandata de fabricant pt ca el a facut niste teste cand a facut acel motor care are anumite tolerante intre piese la rece si la cald si un anumit coeficient al dilatarii pieselor in miscare in functie de aliajul produsului si s-ar putea ca atunci cand tu consideri sa pui un ulei mai gros sau mai subtire decat cel recomandat sa ii faci rau motorului printr-o ungere insuficienta cel mai frecvent la rece ,bine si sa te ghidezi dupa zona unde folosesti acea masina adica intre ce tamperaturi te incadrezi in acea zona .acum dupa ce ti-ai propus sa spunem sa respecti indicatiile constructorului trebuie sa te uiti dupa indicele nivelului de performanta al uleiului .Nivelul de performanta european se noteaza cu ACEA iar cel american cu API ,cel european include indicativele A pt mot pe benzina si B pt cele diesel,Acum cel mai indicat indice de performanta avand in vedere raportul calitate pret este A3/B3 care se gaseste si la cele semisintetice si la cele sintetice ,exista si norme mai inalte dar acele uleiuri sunt scumpe si se schimba la intervale mai lungi de timp,Parerea mea este ca cel mai bun ulei de pe piatra romaneasca este Castrol si Mobil,cu toate ca este relativa un pic situatia deoarece am auzit ca marfa pt piata de Est difera de cea pt piata de Vest adica este mai slaba calitativ.
Mar 13 2006, 12:18 AM
73% BMW corupt Group: Insiders Posts: 746 Joined: 21-December 05 From: Ploiesti Member No.: 135 |
Si cum as putea afla ce ulei recomanda BMW pt. motorul M10 al meu?
-------------------- 316
Lo-Fi Version | Time is now: 29th April 2024 - 01:07 AM |
