2 Pages V   1 2 >
Closed TopicStart new topic
> Vand Workstation/Server/Sistem IBM Intellistation M Pro 6219-46g, +un Tv Tunner Leadtek Winfast tv2000xp Expert
evildeath
post Dec 1 2010, 03:55 PM
pull the rag of the three five
Car: E23
Engine: M30 3.5
Cum spune si titlul vand Workstation/Server/Sistem IBM Intellistation M Pro 6219-46g fara monitor
Specificatii:
* Type Workstation
* Recommended Use Corporate business , Small business
* Product Form Factor Mini tower - 4.0
* Built-in Devices Speaker
* Width 6.5 in
* Depth 19.0 in
* Height 17.4 in
* Weight 42.1 lbs
* Color Stealth black
* Processor
* Type Intel Pentium 4 3.06 GHz
* Installed Qty 1.0
* Max Supported Qty 1.0
* Mainboard
* Chipset type Intel E7205
* Data bus speed 533.0 MHz
* Cache Memory
* Type L2 cache
* Installed Size 512.0 KB
* Cache Per Processor 512 KB
* RAM
* Installed Size 2.0 GB / 4.0 GB (max)
* Technology DDR SDRAM - ECC
* Memory Speed 266.0 MHz
* Memory Specification Compliance DDR266/PC2100
* Form Factor DIMM 184-pin
* Features Dual channel memory architecture , Unbuffered
* Upgrade Rule 2 modules at a time
* Storage Controller
* Type 2.0 x IDE - Integrated - PCI; 1 X SCSI
* Controller Interface Type ATA-100
* Storage Controller (2nd)
* Type None
* Storage
* Floppy Drive 3.5" 1.44 MB floppy
* Hard Drive 1.0 x 36.0 GB - SCSI - 1000.0 rpm
* Hard Drive (2nd) None
* Optical Storage
* Type CD-RW / DVD-ROM combo - IDE
* Read Speed 48x (CD) / 16x (DVD)
* Write Speed 48x
* Rewrite Speed 24x
* Optical Storage (2nd)
* Type None
* Storage Removable
* Type None
* Monitor
* Monitor Type None.
* Graphics Controller
* Type AGP 8x - Plug-in card
* Graphics Processor / Vendor NVIDIA GForce4
* Video Memory 64.0 MB DDR SDRAM
* Audio Output
* Type Sound card - Integrated
* Sound Output Mode Stereo
* Compliant Standards AC '97
* Input Device
* Type Keyboard , Mouse
* Mouse
* Mouse interface PS/2
* Audio Input
* Type None
* Telecom
* Modem None
* Networking
* Networking Network adapter - Integrated
* Data Link Protocol Gigabit Ethernet , Ethernet , Fast Ethernet
* Remote Management Protocol DMI 2.0
* Features Wake on LAN (WoL)
* Printer
* Type None
* Expansion / Connectivity
* Expansion Bays Total (Free) 3.0 ( 1.0 ) x Front accessible - 5.25" x 1/2H , 2.0 ( 2.0 ) x Internal - 3.5" x 1/3H , 2.0 ( 1.0 ) x Front accessible - 3.5" x 1/3H
* Expansion Slots Total (Free) 4.0 ( 0.0 ) x Processor - Full-length , 1.0 ( 0.0 ) x Mini PCI - Socket 478 , 1.0 ( 5.0 ) x Memory - DIMM 184-pin , 1.0 ( 1.0 ) x AGP Pro 8x - Type III , 5.0 ( 2.0 ) x PCI - Full-length
* Interfaces 1.0 x Serial - Line-in - 9 pin D-Sub (DB-9) , 2.0 x Display / video - RS-232E - Mini-phone 3.5 mm , 2.0 x Microphone - Line-out - 29 pin combined DVI , 1.0 x Audio - VGA - 6 pin mini-DIN (PS/2 style) , 1.0 x Mouse - Generic - RJ-45 , 2.0 x Parallel - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Network - Input - 15 pin HD D-Sub (HD-15) , 2.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Keyboard - Generic - Mini-phone stereo 3.5 mm , 1.0 x Display / video - DVI-Analog/Digital - 6 pin mini-DIN (PS/2 style) , 2.0 x Audio - 25 pin D-Sub (DB-25)
* Miscellaneous
* Cables Included DVI-VGA adapter ( 2.0 pcs.)
* Features Diskette I/O control , Secure access openings , Mouse disable , Parallel port I/O control , Power-on password , Administrator password , Security lock slot (cable lock sold separately) , Cover key lock , Serial port I/O control , Keyboard password , Thermal monitoring , U-Bolt anchoring , Hard drive I/O control , Boot sequence control , Boot without keyboard or mouse , Fan speed monitoring , Voltage monitoring
* Compliant Standards C-Tick , NOM , APM 1.2 , cUL , ICES-003 , FCC Class B certified , TUV GS , ACPI 1.0a , EN 60950 , IEC950 , ZH1 618 , CE , BCIQ , VCCI Class B ITE , UL 1950
* Power
* Device Type Power supply
* Power AC 120/230 V
* Power Provided 340.0 Watt
* Environmental Parameters
* Min operating temperature 50.0 �F
* Max operating temperature 95.0 �F
* Operating humidity range 8 - 80%
* Sound emission 56.0 dB
* Operating System / Software
* OS Provided Microsoft Windows XP Professional
* OS Certified Microsoft Windows 2000 Professional , Microsoft Windows XP Professional , Red Hat Linux 7.3
Sistemul este in stare perfecta de functionare. Are licenta de XP si Linux instalat pe el.
Ideal ca server ( a fost folosit la o retea de 200 de persoane pentru routare, limite, interfata de management, hosting si server e-mail), ca workstation(autocad etc) sau ca pc.
ARE UN SINGUR HARD PE SCSI DE 36GB LA 10000 ROT/MIN
ARE FIREWIRE, PLACA DE BAZA MAI ARE 2 PLACI EXTENDED
A fost cumparat anul trecut de la PLUS PC cu aproape 12 mil
Pret 6,5 mil usor negociabil
se vinde si un Tv Tunner Leadtek Winfast tv2000xp Expert
pachet complet ce contine- tv-tunner-ul
-telecomanda
-senzor telecomanda
-antena fm
pret: 1 mil
0724014184
Attached thumbnail(s)
evildeath
post Dec 15 2010, 07:23 AM
Car: E23
Engine: M30 3.5
up 600 RON
post Dec 15 2010, 12:18 PM
Asa sisteme erau facute sa tina o viata.
Inline 6 in a 5-er 4 ever
MeHigh
post Dec 15 2010, 12:57 PM
Roadrunner
Car: E39
Engine: M57D30
da, am dat si eu la casat 5 servere Dell cu o configuratie apropiata de a astuia, mergeau fara probleme, nu a crapat nimic in 5 ani cat au fost folosite. le-am schimbat pentru ca au iesit din garantie.
succes la vanzare, e un fel de tanc serverul.
Cash only, no I will not trade + cash for your ETA, nor do I want any wheels, ex girlfriends, puppies, or sexual favors....well maybe but PM me about that one
evildeath
post Dec 17 2010, 02:23 AM
Car: E23
Engine: M30 3.5
intradevar sunt bulletproof...up in continuare cu el si pret-ul usor negociabil
evildeath
post Dec 24 2010, 03:49 AM
Car: E23
Engine: M30 3.5
up!
evildeath
post Jan 4 2011, 09:15 AM
Car: E23
Engine: M30 3.5
brown.shark
post Jan 4 2011, 10:27 AM
Car: e 28
Engine: m 21
QUOTE (MeHigh @ Dec 15 2010, 12:57 PM) *
d c nu le-ai pus aici ? poate interesau p cineva. e pacat sa arunci asa ceva totusi.
post Jan 4 2011, 11:50 AM
or fi fost la serviciu. Daca procedura cere casare nu stiu cum, n-ai ce sa-i faci.
La noi casarea se face asa:
- impachetat si trimis in Germania, unde se face licitatie.
- donatii
MeHigh
post Jan 4 2011, 03:49 PM
Roadrunner
Car: E39
Engine: M57D30
la mine la servici se caseaza obligatoriu toate echipamentele electronice, inclusiv bateriile de la camera foto le dam la casat. au venit niste betivi si le-au luat, erau de la o firma de preluari deseuri (EcoTic parca ii zice), au cazut cu ele pe scari, probabil au crapat componente prin interior, insa nu pun suflet in astea, numai in fiarele cu roti si volan.
post Jan 4 2011, 04:05 PM
zijdelings geïnteresseerd
Si la noi e greu sa pui mana pe ceva dat la casat. E mai degreaba o miscare de contabilitate, nu e directionat spre refolosirea de echipament.
brown.shark
post Jan 7 2011, 09:20 AM
Car: e 28
Engine: m 21
e o stupiditate generala, sunt sigur ca se arunca zilnic in RO macar 100 de PC de la firme, nu ma pricep eu asa d bine dar cred ca daca sunt curatate si fizic si IT ar putea fi date scolilor, nu cred ca ar face rau cuiva....costa mai mult sa le reciclezi.
post Jan 7 2011, 09:37 AM
Da, inchi[uie-ti cat costa transportul si depozitarea in DE pana cand se facea licitatie sa le dea pe nimic.
Anul trecut le-a venit mintea la cap si au facut cateva donatii in tara.
post Jan 7 2011, 10:56 AM
Da, in caz de multinationale in Romania cred ca este o politica copiat de la tara de origine, unde probabil sisteme de gen nu mai reprezinte un interes nici macar pentru scoli, orfelinati, .... . Aici in Romania cred ca ar fi foarte util un fel de asociatia caritabila care strange astfel de calculatoare si le distribuie apoi la zone in tara unde exista lipsa.
Chiar si un calc de 7 - 8 ani este inca foarte bun pentru educatia. De fapt, cam atat are si calculatorul meu la munca si inca e ok, doar ecran e inlocuit si am mai adaugat RAM.
brown.shark
post Jan 8 2011, 10:12 AM
Car: e 28
Engine: m 21
cu tot traiul asta chinuit, genetic romanii nu-s prosti, un copil cu o baza buna, sigur se dezvolta mai bine pt el si indirect pt societate daca poate sa invete, sa se instruiasca, un PC la S-H e f bun cativa ani in loc de tigari / bere si seminte cu golanii pe bordura. radem glumim dar mai trb si sa aiba cine sa ne plateasca pensiile....
evildeath
post Jan 15 2011, 03:56 PM
Post #16
Car: E23
Engine: M30 3.5
550 RON
evildeath
post Feb 5 2011, 05:40 PM
Post #17
Car: E23
Engine: M30 3.5
up!!!
Dani88br
post Feb 14 2011, 07:25 PM
Post #18
45% BMW corupt
Car: e36
Engine: M41 1.7TDS 90CP
Sa nu crezi ca sunt rautacios si ma bag aiurea in seama, iti dau pe calcul ala 150 lei, e destul de slab procesorul la frecventa aia si L2 512k(cacheul ala il aveau procesoarele BARTON de 2.8 din 2004), foarte slab! placa video agp, slot ram sdr, imi pare rau sa te anunt dar ai luat teapa decand l ai cumparat!
Eu vand la 600lei un copm cu procesor Intel pe socket 775, la 3000, cu L2 chace de 2000k, bus de 800mhz, 2gb ram DDR2 la frecvente 1600mhz, placa video 8600GT(512mb/256bits), slot PCI, hard de 500 SATA, DVD-RW Asus...etc
Sincer, dar sa nu te superi, mi se pare pretul exagerat de mare ptr tehnologiile alea primitive, o fi el IMB dar ma uit si la ce face, cu ala mai mult de internet explorer si mess, nu ai ce face cu el, nici de torrent nu ii bun, are hdd ul mult prea mic.
This post has been edited by Dani88br: Feb 14 2011, 07:31 PM
Uploaded with ImageShack.us
www.bmwinfo.com
www.autodata.ltd.uk
www.e34.de
www.e36.de
www.e30.de
post Feb 14 2011, 07:49 PM
Post #19
Dani, pune serverul ala sa tina forumul asta, apoi pune-l si pe-al tau. Vedem care tine mai mult de trei luni (cu indulgenta si cu cateva reboot-uri bonus la al tau) wink.gif
Bine ca n-ai zis de sursa. Pe vremea aia desktop-urile IBM aveau sursa de 180W care tinea mai bine decat chinezariile de 350 existente pe piata. Asta de 340W tine o casa biggrin.gif
E adevarat, cam greu gasesti client exact pentru tipul asta de calculator... dar isi are valoarea lui.
evildeath
post Feb 15 2011, 03:09 AM
Post #20
Car: E23
Engine: M30 3.5
QUOTE (Dani88br @ Feb 14 2011, 07:25 PM) *
tocmai d'aia am scris ca e server si nu calculator, sa faci surf pe net cu el, sa asculti muzica si sa downloadezi pornache. Este un pc calculator a tinut o retea de cartier, a functionat pe linux, si a avut functie de routare, de limitare pe extern si de hosting fara a avea cea mai mica greata.E vorba de cum e construit. La pc-ul meu schimb la el odata la juma de un an ceva ca mi se arde, asta a mers 3 ani non-stop si nu a patit nimic. Daca te gandesti la domeniul lui poti sa-ti dai seama ca nu e teapa si ca nu il voi da cu 150 de lei !
cat despre hdd si placa video cum ziceam nu e gandit pentru pornache... pe el se folosesc 90% aplicatii fara interfata grafica si prin urmare fara nevoie mare de spatiu , ci de harduri scsi pentru viteza lor de scriere+citire si pentru cat de robuste sunt
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 7th October 2025 - 06:40 PM
