BMW Wheel Hub diameter and sizes, Hub Centre Bore Sizes and ET/Offset, Jante BMW |
Dec 24 2013, 05:47 PM
All ET/OFFSET is still dependent on tyre and wheel size so bear this in mind if you are trying to fit wheels from one model to a different model, also if the car is lowered then you may have issues with rubbing/non fitment due to fouling.
The higher the ET number the more the wheel will sit inside the wheel arch 1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45 1 Series E82M = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 20-31 1 Series F20/F21 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 33-53 3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20 3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35 3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30 3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47 3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47 3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47 3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27, 3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45 3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37 3 Series F30/F31 = PCD 5x120, Centre bore 72.5mm and M14x1.25 bolt thread. ET 31-47 5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25 5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20 5 Series E34ix (4x4) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 46-55 5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 20-22 5 Series E39 = PCD 5x120, centre bore 74.1mm and M12x1.5 bolt thread. ET 15-25 5 Series E39 M5 = PCD 5x120, centre bore 74.1mm and M12x1.5 bolt thread. ET 15-25 5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32 5 Series E60/61 xDrive = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 40-46 5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32 5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32 5 Series F07 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 25-41 5 Series F10/F11 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 33-44 6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-22 6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20 6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20 6 Series F12/13 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 30-44 7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26 7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25 7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25 7 Series F01/02 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 25-41 8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 10-19 X1 E84 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-41 X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-46 X3 F25 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 32-51 X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45 X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53 X5M E70 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.25 bolt thread. ET 18-40 X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.25 bolt thread. ET 38-40 Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 24-25 Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-41 Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 20-41 Z4 E85/86 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52 Z4 E89 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 29-40 Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 20-22 BMW Mini R50/R52/R53 = PCD 4x100, centre bore 56.2mm and M12x1.5 bolt thread. ET 37-48 BMW Mini R55/R56/R57/R58/R59/R60 = PCD 4x100, centre bore 56.2mm and M14x1.25 bolt thread. ET 37-48 This post has been edited by Halogen: Dec 24 2013, 05:49 PM |
Dec 25 2013, 10:13 PM
Posteaza si link-ul aici: http://bmwzone.ro/forums/index.php?showtop...20&start=20
Lo-Fi Version | Time is now: 25th May 2024 - 02:45 AM |
